Keep VAF
Going
12-25-2021, 02:59 PM
First flights unknown noise
My friend's RV-14 has about 7 hours on it. Today he said he was trying to figure out what is causing a noise that sounds to be coming from down by his feet. It is only noticeable or occurring when he reduces the throttle for landing. Today he said he made some slow flights and while reducing the throttle no noise was heard. He says he has been running the engine hard ( more than I would, I broke mine in at 25 squared and I'm not burning any amount of oil, normal 1 quart in 8 to 10 hours). I'm wandering if he's not running the EXP239 very hard and reducing power too fast . He thinks it's perhaps backfiring when he is reducing power. I'm thinking of having him reduce power overhead tomorrow so I can see if I hear anything from the ground.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
12-25-2021, 03:20 PM
Exhaust Backfiring?
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
(KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis, floats.
Current Project Javron Super Cub
Thank You Doug!
12-25-2021, 05:23 PM
If he doesn’t have any carpet the floor resonance is pronounced at certain power settings.
12-25-2021, 07:52 PM
I changed the short metal hangars to belting and it got rid of a lot of sound and vibration in the floor area
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
12-26-2021, 05:49 AM
He does have carpeting.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
12-26-2021, 05:50 AM
WE are having trouble with one hangar slipping. Plan on addressing this today.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
12-26-2021, 02:26 PM
I used to hear a funny noise coming from the right side of the Boeing, then I realized it was the co pilot!
Grin....
G.
12-26-2021, 05:02 PM
My friend tried not bringing the engine to an idle position on landing approach as if I recall correctly was Mike Seager’s instructions. A few flights today seamed to reduce the backfire considerably.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
12-26-2021, 05:32 PM
Backfiring on throttle reduction / idle or close to, is pretty normal in these beasts. You can gentle the reduction to minimize it but I usually get some popping when reducing power for landing regardless of technique.
Randall Henderson
RV-6 / O-360 / CS, 1600+ hrs, 1st flight Sept. 1999
Outstanding Workmanship OSH 2000, Craftsmanship award AWO 2000
Airport committee chair & AOPA ASNV for Seaside, OR Municipal (56S), www.seasideairport.org
Last Donated January 2022
12-26-2021, 05:39 PM
Could it be…
…after-fire? In my -14 w/an IO390X I would get what was termed after-fire if I brought the throttle rapidly to idle. It also happened at idle at an airspeed above 80KIAS. That made glide testing disconcerting cause gliding at idle at best glide would cause the event. Adjusting idle mixture seemed to help.
Jeffrey T Jones
RV-14 N588TJ Completed
First Flight July 10, 2018
Flight testing completed August 14, 2018
2021 VAF dues paid plus beer money😜
Thread Tools |
Display Modes |
