Keep VAF
Going
11-29-2021, 11:24 AM
I am learning from this thread. I have been going over my flight data and seeing my oil temp is not going over 135 though my cylinder temps are in the 370-400 range and exhaust temps up to 1480 at peak, mostly around 1400.
I preheat my engine overnight like this photo and I get the oil to about 75 and the carb to about 90.
I can see the oil needs to get hotter but my exhaust temp is as high as I want it to go. My thought is to cover part of the oil cooler or plug the blast tube on it but I dont want the other temps to go up.
Am I over focused on the exhaust temp?
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
11-29-2021, 12:54 PM
rockwood: place your EGT probes 2" lower on the exhaust pipes to solve your high exhaust temp problem.
your CHT's and Oil temps matter, EGT's shouldn't.
11-29-2021, 01:22 PM
Thanks. That makes me feel a bit better. I was using them to help me lien the engine.
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
12-09-2021, 06:36 AM
I am ok in the pre heat but having trouble getting the oil up to temp in flight. After an hour flight the max the oil got was 131degrees. My plan is to put aluminum tape over the outside of the oil cooler. I’m sure putting it on the inside of the plenum would be better but thought I would try this first. Is there a reason to not try this? I tried taping the front of the plenum holes 1/3 and it increased the CHT but did nothing for the oil. Any thoughts?
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
12-09-2021, 08:01 AM
With exhaust gas temperature, I think what matters is not the actual number but the trend. I've been told that using EGT for anything other than finding the peak temp and adjusting mixture rich or lean from there is the not very useful.
RV-9A, 2011, bought flying
IO-320D1A (factory new), C/S
IFR equipped
AFS 5400/3500, G5, IFD440 navigator,
bunch of other stuff
12-09-2021, 09:00 AM
Thanks. I agree - Im not to worried about the exhaust gas temp but I want to make sure I can keep the oil temp high enough. I hoped putting the tape on the outside of the oil cooler would help so I didnt have to take off the plenum to cover the inside.
You are in cold town USA so how do you keep your engine oil hot enough? Im having trouble betting to 120-130.
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
12-09-2021, 11:18 AM
Get that nice plenum off and tape inside the cooler. Completely. You would be pleasantly surprised what it does. When it's very cold tape both sides.
Tape at the back as shown will eventually peel off due to a lot of air pushing on it.
12-09-2021, 12:35 PM
I agree with Vlad. I have a cable actuated shutter on the front of the cooler and this time of year it is almost completely shut all the time.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
12-09-2021, 12:40 PM
As a reference: I have a good cowled airplane and always have cool - cold CHT. I tape almost 100% of the cooler almost all winter. Live in the Chicago area. I fly south just N of Atlanta before I stop for fuel, and I take the tape off then.
12-09-2021, 01:20 PM
Ok, I was lazy but I will tape the inside! Ha!
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
Thread Tools |
Display Modes |
