Go Back   VAF Forums > Education > Flight Testing
Old 01-22-2005, 05:59 PM
Kevin Horton's Avatar
Default Pitot-Static System Errors - How to measure them
Every aircraft with an airspeed indicator and an altimeter has errors in those systems. The errors are due to many factors:
  • Instrument error,
  • Leaks in the plumbing,
  • Position errors in the static system, and
  • Position errors in the pitot system.
Instrument error in the airspeed indicator (ASI) can easily be measured using a water manometer. Instrument error in the altimeter cannot be easily be measured by the builder, but an avionics shop can test it with a pitot-static test set.
Leaks in the plumbing can be easily checked.
Position errors in the static system are caused by the fact that the air flowing around the aircraft has to accelerate and decelerate as it wends its way over the shape of the airplane. The air pressure changes as it accelerates and decelerates, so the pressure at the static port is quite likely different than the free stream static pressure well away from the aircraft. This difference between the sensed static pressure and the free stream static pressure is position error, and it accounts for most of the error in the ASI (assuming the instrument error is small, all leaks are fixed, and the pitot tube is not too poorly located).
The pitot tube is relatively immune to position errors, as it measures total pressure, not static pressure, and the total pressure isn?t changed as the air moves around the aircraft. If your pitot tube is reasonably well aligned into the airflow, and it is well clear of the prop wash, and it is not in the wake of something else, it should be quite accurate. Pitot tubes should provide reasonable accuracy if the local airflow is aligned within 15 degrees of the pitot tube. So, it might become inaccurate as you approach the stall.
I have put together a guide on how to measure ASI instrument error using a water manometer and how to determine static system position error via flight testing. This guide is located at http://www.kilohotel.com/rv8/rvlinks/ssec.html.
Kevin Horton
RV-8
Moses Lake, WA, USA
Last edited by Kevin Horton : 02-27-2005 at 06:50 PM. Reason: ISP jacked around with the URL, so I got a domain name.
Old 07-09-2015, 11:47 AM
kai kai is offline
Hi Kevin, is that guide still available somewhere? I would appreciate to get a copy of that!
Kai
Kai
flying RV-9a, O-320, G3X Touch
a father&son project
Old 07-09-2015, 01:11 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Kai
Here is a corrected link:
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 07-10-2015, 03:47 AM
kai kai is offline
Great, thanks!
Kai
