Sig, you should have a piece of 4130 steel, about 12" X 3/4" wide. It is cut to make 4 pieces, two on each side, that attach the rudder cables to the pedals.
Thanks for this post! I too could not find hardware.
Also, looked at rudder-peddles drawings for hardware. Is AN3-6 the same used on rudder/pedal . . . ?
Have a 93 build 6. Not sure if those bolts have ever been replaced? Will be replacing them as soon as I can confirm bolt sizes.
