Old 06-17-2021, 07:50 PM
charosenz's Avatar
charosenz charosenz is offline
Default 100 hours on engine; going strong
I have not posted much only because I have been busy with non-aviation life. (Moving across the country and building a new home sorta takes a bit of time.)
I just reached the 100 hours on the engine, with about 85 ish of it flight time. I have not had any issues with the engine or the PSRU. I typically run it at about 4500 RPM. I have only added one quart of oil in that time frame. Things seem to be going well with the set up.
Good flying to you all.
Charlie
Now, Magnolia KY.
Charlie Rosenzweig
RV6A - Honda (Turbo) engine. Now flying
SDS-EFI EM4
https://vansairforce.com/community/s...158610&page=70
2021 Dues paid
Old 06-17-2021, 08:44 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Thanks for the update. Congrats on the 100 hour mark.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 449.8 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
https://www.youtube.com/channel/UCiy...g2GvQfelECCGoQ
Old 06-18-2021, 06:15 AM
zolotiyeruki zolotiyeruki is offline
I was just wondering yesterday how you've been getting on with the engine. Sounds like it's been treating you well. Congrats on the milestone!
Old 06-18-2021, 07:20 AM
Tomcat RV4 Tomcat RV4 is offline
Are you running return line or just pressure regulator on fuel injection ?
Tom Hankmp
Tomcat RV4
RV4 gone to RV heaven !building Zenith 701
dues paid and worth every penny
Life is uncertain -Eat desert first !
U F O Member since Dec 2017
Old 06-21-2021, 05:43 PM
charosenz's Avatar
Default return line
Tom Hankmp
Tom,
I am using a return line from the pressure regulator.
Charlie Rosenzweig
SDS-EFI EM4
2021 Dues paid
Old 09-07-2021, 05:48 PM
charosenz's Avatar
Default Update and new variable pitch prol
It has been a while so I thought I would give an update and share some new changes coming.
In short the engine and installation are working well.
I'll describe some things that I need to work on at the end of this post, but off to the good stuff first.
After getting a bit more and more dissatisfied with 20 inches of MAP (Manifold Air Pressure) at 10k ft. and having a Turbo which is really not being used to its full advantage, I have plans to get a variable pitch prop. I know most of the "usual" candidates, MT, etc. but I am more intrigued by the variable pitch prop hub being offered by GR-Engines out of Rostov-on-Don Russia. Ill insert a pic of their hub with this post.
http://gr-engines.ru/en/catalog/propellers/vpp-3-20
For my set up, this seems to have a lot of features that I really like. I will be able to use my current spinner and spinner back plate and more importantly, the warp drive prop blades with their hub. The system has a 5 button dashboard controller that fits nicely in a 3-1/8 instrument hole that allows you to select minimum (climb) pitch, Maximum (Cruise) pitch as well as being able to select increases and decreases a degree at a time. Plus of course it displays the actual pitch at any given moment.
In case readers are wondering, I have spoken to the folks at Warp Drive and they (understandably) take no position on this.
There are a few older versions in the USA on Trikes but for the most are in use oversees. One unit has been sold to NASA for use in the ROAMX program.
I have a prop extension in use already and this will require me to have a new extension made to fit their hub.
It will be a couple of months before the system and extension are ready to ship and more time after that to install. I honestly have no expectations things will come together anytime before December. Which is actually good timing for me as I have more non-aviation obligations right now than I have time for.
More on other squawks in separate posts.
Click image for larger version
Name:	3 blade hub close up end view.png
ID:	15581  Click image for larger version
Name:	5 button dashboard controller.jpg
Charlie Rosenzweig
SDS-EFI EM4
2021 Dues paid
Old 09-12-2021, 07:59 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
It has been 3 years... any update??? I see you have flown it from videos
Update, Empty weight, top speed sea level, cruise at 8500 msl WOT speed and FF?
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2021 Dues Paid
Old 09-12-2021, 08:28 PM
charosenz's Avatar
George,
At first I thought you were kidding. Yes, there have been about 200 posts with updates since I first flew last October. Tons of details there for the curious....
My empty weight was 1036. As far as speed goes, I always want to put some context around "speed". As I am sure many want to see if the "Honda" produces enough power. As you know there is much more to speed than the HP the engine produces. The main limited factor to my top speed is really not related to the engine. They are:
1) A 2.33 ratio reduction drive. With my self imposed top RPM of 5000 this limits my top propeller speed to 2150. So....imagine comparing a top speed of a plane that is turning a prop at 2700 rpm compared to one turning 2145.
2) I have 6 x 6.00 tires.
3) No leg or gear fairings.
4) A fixed pitch prop.
Which is why I am ordering a variable pitch prop. I also hope to soon be able to get some flight time with other RV6A and do some more flight comparisons where we can match prop rpms.......
I would have to check some notes but I think I see 150 mph at sea level at 2060 prop RPM.....
Charlie Rosenzweig
SDS-EFI EM4
2021 Dues paid
Old 09-13-2021, 07:16 PM
6ato14a 6ato14a is offline
Default Big tires
Charlie
How did you put the big tires on? What did youdo to the nosewheel? I would love to call you about that whole process and how you like it. You cam pm me or call me at 303-772-2202 or email me at klmoexpo@gmail.com
Dave
Old 09-13-2021, 08:29 PM
Originally Posted by charosenz View Post
George,
At first I thought you were kidding. Yes, there have been about 200 posts with updates since I first flew last October. .
Sorry did not see the other post. Thanks for update. From video sounded good. Thanks for quantifying speed... The CS PROP will be a great change. Good luck.
George
Raleigh, NC Area
2021 Dues Paid
