Old 09-10-2021, 06:34 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Default Coolant Loss…
I notice a slight decline in coolant level in the overflow tank – maybe 1/16” to 1/8” change in level over 20 hours operation. I have removed cowling and looked for leak and found none. At end of flight coolant level is at fill line and when engine cools level is 1/16” to 1/8” lower.
I’d like to know if this is common and if other planes ae experiencing the same coolant loss.
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 735
Old 09-10-2021, 06:45 PM
DHeal DHeal is offline
Sounds normal to me -- the coolant level in the overflow tank will vary a bit depending on the temperature of the coolant. I would expect some slight loss of coolant over time due to evaporation and tank venting.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,070+ hours (as of Sep 2021)!
VAF donation through June 2022.
Old 09-10-2021, 08:36 PM
NinerBikes NinerBikes is offline
Next time you have the cowling off, on the bottom, if the leak continues, check the weep hole on the bottom of the water pump for coolant residue, or very slow dripping.
If it's dribbling, or there is residue there, time for a new water pump.
Some other ideas...https://pointsforpilots.blogspot.com...12-engine.html
Donated
RV-12, KWHP based
"Time to Spare, go by Air."
Old 09-10-2021, 09:23 PM
Charlie12 Charlie12 is offline
Default coolant loss
My overflow tank level creeps down roughly 1/4 inch between annual inspections. I have checked carefully for leaks and have never found any.
RV-12 #120768, first flight Sept. 2016
344 hrs as of 8/27/2021
Old 09-10-2021, 09:35 PM
Mine uses about that much coolant too.
Old 09-10-2021, 11:48 PM
[/url]
Not necessarily true. Some pump leakage is permitted by ROTAX -- see Paragraph 1.5: https://legacy.rotaxowner.com/si_tb_...o/si912001.pdf
