Old 03-04-2021, 09:59 PM
Jake14 Jake14 is offline
here's a thread.....
https://vansairforce.net/community/s...d.php?t=150952
RV-14A flying 450 hrs
Old 03-05-2021, 06:52 AM
Crafting N112DR's Avatar
Crafting N112DR Crafting N112DR is offline
Originally Posted by RFSchaller View Post
Dave,
Having the wings on would increase the moment of inertia, but the torque on the engine mount is the same with and without wings. The wings just make it less obvious when looking out the windo.
Rich
I said nothing about the torque on the engine mount. I said airframe.
From Scott" The reason it is not recommended on the other RV models has nothing to do with fuselage strength (and it is not because of a fear of it rolling over). It is because of the inertial damping in roll that the wings provide.The majority of the shake induced by a Lyc. is in roll. Without wings installed, there is much less mass to limit the shake.
There are documented cases of RV's having elevators and rudder damaged because of an engine start/shut down without wings installed.
Can it be a problem with an RV-12? Probably not, but I cant' say for sure because we choose not to take the chance."
___________
David Rohrlick
PPSEL, A&P
N112DR (RV-12iS)
Airworthiness signed off by the FAA 1/23/2020
First Flight on 3/14/2020
Phase I Finished on 5/7/2020
Need:
Paint?
Serial#12-0864
https://youtube.com/c/CraftingN112DR
VAF donation made for 2021
Old 03-05-2021, 09:14 PM
Can you point me to a discussion of those documented cases? I find it difficult to believe the tail feathers are that fragile, but I have an open mind to the data.
Old 03-06-2021, 06:37 AM
thiggins thiggins is offline
Look at the link in post #11 below. Vans (the kit manufacturer) says itís not recommended...So why would we think itís ok?!?
Donation 2020 paid
ASEL INST COMM Tail-wheeler
RV-12iS (Building it's shop right now...)
Old 03-06-2021, 07:29 PM
Like I said, Iíd be interested in reading the documents on the documented cases to better understand exactly what happened. I have an open mind, I just like it when statements have some objective evidence to evaluate for myself.
