Old 02-28-2021, 11:52 AM
Ken Patton Ken Patton is offline
Smile Landing lights
Putting in my order for the RV12is wing kit. Should I order the second landing light or just go with only one??? Please let me know your thoughts. Very reason from cost , to maintenance, burden to electrical system, to the extra time and effort to install. I wont respond but I will thank now for your input. (THANKS)
Old 02-28-2021, 11:59 AM
jrtens's Avatar
jrtens jrtens is offline
I would go with two. The wig wags are probably the most effective tool against a mid air collision.
Jon
12iS SLSA #5
Salt Lake Int'l
Old 02-28-2021, 12:32 PM
NinerBikes NinerBikes is offline
I would also go with two, from a visibility standpoint.
Donated
2012 RV-12, #212 N72DJ KWHP based.
Old 02-28-2021, 06:36 PM
rv9builder rv9builder is offline
I agree. This is the reason I ordered two.
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2021
Old 02-28-2021, 06:58 PM
Thumbs up
Thanks again for responding. I will agree that the safety aspect alone is enough reason for two. So two it is👍🏻
Old 03-01-2021, 04:46 AM
thiggins thiggins is offline
It does require the injected IS engine, but you probably know that. So, its not just the additional light kit.
Donation 2020 paid
ASEL INST COMM Tail-wheeler
RV-12iS (Building it's shop right now...)
Old 03-01-2021, 07:22 AM
John-G John-G is offline
Ken -
I installed the second landing light just to have wig-wag capability to hopefully make it easier for other aircraft to see me, especially in the pattern ... which from a safety aspect, I feel is money well spent. See and be seen.
I have a 912ULS engine so the electrical system is rather anemic, but remember ... in the wig-wag mode one light is always off, so there is no more current draw then having the right landing light steady on.
Your 912iS has a more robust charging system than the 912ULS so doubt you will have any issues with taxing the electrical system. In my case, to help minimize the current draw during night operations, when the panel switch is placed in the landing light steady position, it only lights the right landing light. I placed a separate switch on the panel to control the left landing light's steady on ... on short final I can switch it on and when on the runway switch it off ... this way the electrical system is not over taxed from both lights being on for extended periods of time. Photo of the left landing light switch:
https://3.bp.blogspot.com/-beurgpsfy...0/DSC01555.JPG
Happy building,
John
http://www.dogaviation.com/
RV-12 Wings, Empennage, Fuselage, Finishing, Avionics and Powerplant kits all completed
Now Flying!!
Donation paid until September 2021
Old 03-01-2021, 05:21 PM
Originally Posted by jrock836 View Post
John, if you don't mind me asking, where did you buy those switches and the backing plates with lettering?
Joe - don't want to hijack this thread so PM me if you need more info than can be found in the following link to my Blog.
http://www.dogaviation.com/2016/03/f...-switches.html
The label material is a two layered .020" thick engraving material carried by most engravers with a thin adhesive backing applied after engraving. I supplied them with a to scale drawing that they used to engrave and make the cuts for the switches.
The switches are the same ones Van's uses ... they are manufactured by Otto and the part number is in the Blog link. The switches are sold by various vendors.
John
Now Flying!!
Old 03-03-2021, 12:39 PM
PilotBrent PilotBrent is offline
Only have one myself (2nd wasn't an option when I built). Last flight on final, an aircraft on ground radioed me to advise that my "second" flashing light was not working, wanted me to be aware.
If I had the choice, I would have installed 2 of them.
Brent Connelly
Hackettstown, NJ
RV-12, N913BC
http://www.mykitlog.com/brent45
Check out & subscribe to my Youtube channel for latest RV-12 flying videos...
https://www.youtube.com/channel/UCxQ...Px2I7jmazGdLqg
Old 03-05-2021, 03:10 PM
dsm8 dsm8 is offline
Default Landing Lights
This is just my two cents, but I would consider installing the lights prior to attaching the skin to the ribs. I am on my third iteration and am seriously considering drilling out the skin and replacing it with a new one. Follow the instructions in the KAI for putting the light in, but before it is permanently attached to the ribs. This way if you need access to the back and sides, it will be unimpeded.
Again, just my thoughts
Don "Donnie Mac" MacMillan
RV-12 12808
Finish kit 80% done 80% to go
donald.macmillan@ynhh.org
