Currently planning the panel and cables that penetrate the firewall. For those that are currently flying the RV-14A or the -14, have you installed an oil cooler shutter to help with cooler temperatures at the higher altitudes or the colder winter months? I noticed Vans sells one and also Anti-Splat. I wanted to get opinions if it is needed. Much easier to install now.
As mentioned above, I will be using the IO-390 EXP119 with the newer lower cowl design and the cowl exit door.
Best,
Jim
Best,
Jim
