Scott Hersha
I’m building another RV6 from a used kit I recently purchased. I am working on firewall component installation on this nearly completed airframe and I have a couple questions relative to firewall fire protection. First, is this kit from Spruce what I should be looking for as far as materials go?
https://www.aircraftspruce.com/catalog/appages/firewall2000kit.php?clickkey=1032084
Second question….. when should this be applied? I’m assuming it would be after all the firewall mounted equipment is installed (cutting around those objects), but before the engine is mounted, but there may be a better sequence. If the materials listed above are not adequate, please let me know what you recommend.
