dsmithlib
Active Member
I am finishing up the wing wiring and encountered a challenge at both ends of the wing. There will necessarily be service loops of wire at both ends of the wing to facilitate putting on the wing and the tip.
What have others done so that these loops are secured as the wing and then the tip are installed? It almost seems like I would need a spring loaded solution to retract the loops into place as installation progresses?
Dave
Dave
