Old 11-07-2021, 11:01 AM
bsbarnes10 bsbarnes10 is offline
Default Non-dimpled nut plates on dimpled holes? Lower Firewall and Firewall Shelf
We've just gotten the forward section of the fuselage and on page 22iS/U-03 (rev. 1) in steps 2 and 8 you are directed to rivet K1000-3 nut plates to the Lower Firewall (F-01201C-1) and the Firewall Shelf (F-01201B-1). In both steps the parts that the nut plates are being riveted to are dimpled for flush rivets but the nut plates are not dimpled, nor are you instructed to dimple them. Is this correct? If installed this way there will be a small gap between the nut plate the corresponding part.
Up to this point in the fuselage, the majority of nut plates have been pre-dimpled for flush rivets. I do seem to recall at least one location where a non-dimpled nut plate was installed on a dimpled component but I think this was specifically noted in the plans.
I searched the forums and couldn't find anyone else asking this question so perhaps this is a normal practice (non dimpled nut plates on dimpled components) but it's new to me so I just want to confirm with the experts out there....
Bruce
Dues Paid! Thanks for all the help...
Old 11-07-2021, 11:17 AM
Ralph Inkster Ralph Inkster is offline
I dimple the nutplates. I think the mounting screws/bolts are more secure that way.
Some folks don’t.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 11-07-2021, 12:46 PM
GeoffP's Avatar
GeoffP GeoffP is offline
Like Ralph said, dimple them. You'll most likely need a ground down or reduced diameter female die though, and I suggest after dimpling that you carefully bend the tabs straight. They're much easier to rivet if they sit flush onto the surface and dimples.
RV-9, Empennage and Wings about done, Fuselage taking shape.
Old 11-07-2021, 04:20 PM
ralph skorupa ralph skorupa is offline
Default Plate nuts
Many of us use “oops” rivets to fasten plate nuts . The head is so small you can machine countersink even in thinner material
Old 11-07-2021, 07:50 PM
fr0gpil0t fr0gpil0t is offline
I think it's an error in the manual and I stare at the results everyday as I'm now working on the engine ;-)
I didn't dimple the nut plate and it sits awkwardly on the back of that dimple. Now with more building experience I would have probably caught it but at the time I'm was thinking I assume there is a reason for not dimpling.
I would drill it out but it's those pesky stainless steel CCR rivets that love to spin in the hole. So I live with it.
Robert
Old 11-08-2021, 01:38 PM
Thanks guys, based on these responses we decided to dimple them and I think that was the right choice.
(I sure hope so, anyway, because you're right, drilling out those CR rivets is a pain in the butt!)
-Bruce
Old 11-09-2021, 07:57 AM
HFS HFS is offline
Default What I Did - "Dimple Shim"
These "shims" are available commercially, or so simple - just MYO.
Pretty self explanatory - a shim between the offending dimple and the nut plate.
HFS
Click image for larger version
