Old 11-07-2021, 09:31 PM
rv9builder rv9builder is offline
Originally Posted by jetset44 View Post
Bending the tube by hand works but leaves the tube flattened and the curve uneven.
Have you tried using bending springs?
https://www.amazon.com/General-Tools.../dp/B00004T827
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2021
Old 11-07-2021, 11:41 PM
jetset44 jetset44 is offline
Yes, just did an hour ago and that did the trick. Was able to make the piece match the plans without significant flattening of the tube by using the bending spring. Problem solved! Thanks for the tips, everyone.
Old 11-07-2021, 11:59 PM
Steven, are you building a 12 or 12iS? If it's a 12iS, which piece of tubing did you use the bending springs on?
Mark
RV-12iS Fuselage
RV-9A Project: Sold
Old 11-09-2021, 12:22 AM
Yes, I'm building an RV-12iS. The tube here is the one that connects the fuel tank outlet to the drain valve.
Old 11-09-2021, 09:02 PM
Thanks, Steve!
Mark
RV-12iS Fuselage
RV-9A Project: Sold
