Old 06-26-2021, 08:17 PM
fr0gpil0t fr0gpil0t is offline
Default Fitting wiring harness
I'm fitting the Dynon wiring harness and cannot get the connector to the co-pilot's control stick to reach. Does anyone have some images I can look at or check mine to see if there is anything I've miss routed.
I think I have the main harness correct as it leaves the avionics bay. I can't clamp it as the mounting plate for the clamps come in the engine kit. It seems to be about 4 or 5 inches short even after I tried pulling back some of lacing.
This is the wire exiting the avionics shelf
Then the side of the plane showing the connector short of the cutout it should go into
This the wiring under where the throttle quadrant will be
Old 11-23-2021, 07:40 AM
BobbyLucas's Avatar
BobbyLucas BobbyLucas is offline
Did you get this figured out? It appears you may be trying to reach the wrong hole with the copilot connector because it looks like you have plenty of wire to reach the correct hole, which is down and to the right from the large round hole in your pic.
Bobby Steinmetz
Van Buren TWP, MI
Student Pilot, Mechanical Engineer, Donating Member
RV-12iS #121228
  • My opinions are JUST my opinions, not facts
  • Regardless of phrasing or colorfulness, my opinion does not imply that any opposing opinions are wrong or ANY less valid than my own
  • Respect people by giving your own opinion without attacking or belittling others
  • Passive-aggressive is not better than overt-aggressive
  • When I fail to meet these standards, please call me out, gently
