Old 11-17-2021, 09:58 PM
jamjac jamjac is offline
Default RV 12iS wiring
Helping a friend build an RV12iS with a Dynon panel and garmin transceiver. On page 42MIS/U14 shows wire K6284 in several location and I am unable to figure out what is supposed to go where. If anyone has an answer to how this is to be deciphered I would be very happy for the help
Old 11-18-2021, 07:05 AM
Bob Y Bob Y is online now
Itís the generator B ground wire. You should find a white jumper wire with ring terminals on both ends in your wire harness kit. One end goes under the brake-fluid reservoir mounting bolt and the other end goes to the generator B ground stud. If you look on the last page of the wiring diagram youíll see that wire.
Bob Y - builder 12iS E-LSA
N569TT first flight 2/9/2020
#121047
Old 11-18-2021, 07:42 AM
Mich48041 Mich48041 is online now
In addition to what Bob Y wrote, ground also goes to a switch that ties Generator A
and Generator B grounds together for starting and for emergency backup.
Joe Gores
RV-12 Flying
