Old 10-25-2021, 06:26 PM
rileyspoon rileyspoon is offline
Default Exhaust System disassembly required?
My exhaust system came with the exhaust pipes already connected to the muffler with the springs already attached.
The KAI has each exhaust pipe being attached individually, then anti-seize paste is applied to each ball joint receptacle. So am I supposed to remove the springs, disconnect the pipe from the muffler, apply paste and put it back together again?
Riley Spoon
Building RV-12iS
Twin Lakes (8A7) Advance, NC
N488ZC reserved
Old 10-25-2021, 11:19 PM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Yes. And you probably need to disassemble it more than once when you fit the cowling. The springs come last. Stick to the KAI and you‘ll be fine.
Chris, RV-12 S/N 120832, HB-YSC
Facebook: http://www.facebook.com/magic.carpet.aviation
YouTube https://www.youtube.com/channel/UCLw...nv3vJiqAYoE-dg
=VAF= dues paid for 2021
Old 10-26-2021, 05:03 PM
JwWright57 JwWright57 is offline
Also safety wire the springs when they are installed for the final time (you'll probably take them on/off a few times until the engine and exhaust are situated properly)
Jeff Wright, Charlotte NC
Rv-12is with 912is and Dynon system.
Certified Aug 2021
Dues paid 2021
Old 10-26-2021, 06:07 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Might also install Stainless Steel exhaust springs - they last a long time...
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 750
Old 10-27-2021, 12:47 PM
printbr printbr is offline
Tip of the week:
I think I got this tip from someone on this forum. I have found that a strong shoelace works like a charm to pull those springs on and off. And it does not nick the spring end potentially weakening it.
Bruce Rawlins
Richland, WA
LSRM-A
RV-12 Flying
