Has anyone added brake return springs to the stock master cylinders of the 14? I've had a dragging brake occasionally and had trouble replacing brake fluid from the calipers up. When I put a bungee cord on the top of the pedals to pull them back, the fluid flowed much better.
This seems to be a fairly standard mod on other RV's. Just wondering which springs and retainers to use...
Also wondering which is the best hi-temp lube to use on the brake pad guides
Thanks for any suggestions
