Caribbean10
Member
So the RV-10 build instructions tell you to match drill the HS spar caps into the spar flanges using a 3/32" drill (Not a #40 drill). In a later step, you come back and final drill some of those holes using a #40.
My tool kit didn't come with a 3/32" bit. So can I match drill these holes using #40 or do I have to use a 3/32"? And if I do have to use a 3/32, would I be fine using my regular Home Depot Dewalt multipurpose 3/32" bit or do I need to get something better?
