Hello,
I’ve got a factory built 2013 RV12 ULS with Dynon classic view, Garmin SL40 radio, Flight com 403 intercom, auto pilot, and ADSB.
PROBLEM: When radio is receiving I it get static with the radio call.
Intercom works great, my transmissions to others are clear. NO STATIC OTHER THEN WHEN I RECEIVE. I’ve spent about 10 hours checking wires, connections, turning off lights, turning off Dynon, off ELT, replaced intercom, had Garmin radio bench tested, reseated/sealed antenna, even took it to an avionics shop and spent $2000 for them to replace the coaxial cables with shielded ones. Also I did find initially a loose ground on the connector behind the tray, tightened, ALL NO HELP.
Everything worked good for about 4 hours and then the static returned with a radio call randomly and looks like it is here to stay.
I’m hitting a wall on this one and desperate for some help with a solution. Any ideas on what else I should do specifically or things to try?
