Go Back   VAF Forums > Model Specific > RV-14
Old 08-31-2019, 01:10 PM
mjanduda's Avatar
mjanduda mjanduda is offline
Default Distance between center of pilot and center of copilot
Hi,
I am currently making some drawings of my RV-14 panel.
What is the distance between the center of the pilot's seat and the center of the copilots seat? Should probably be the same distance like the distance between the control stick centers.
I want to put the PFD/MFD in the center of the person and not a bit too far to the left/right.
Thanks a lot!
Malte
Old 09-01-2019, 10:43 AM
kbalch's Avatar
kbalch kbalch is offline
Maybe ask Stein Air for their cutting dimensions...?
Ken
RV-8 N118KB (#81125) - Sold
RV-14A N114KB (#140494) - Sold
RV-14A.com
N114KB Build Site
Old 09-01-2019, 02:07 PM
mjanduda's Avatar
I think I'll simply ask Van's.
Old 10-19-2021, 02:04 PM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
Did you ever get your answer?
Pete
RV14A Tail kit 95%
Wing kit 95%
Fuselage QB stuck in China virus corrosion purgatory
RV 14 WIKI in Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
please purchase the thumb drive Vans offers. I DO NOT want to take away from sales flow or get the WIKI Killed.
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 18,19,20,21 Military exempt
Old 10-19-2021, 03:14 PM
cajunwings cajunwings is offline
Default PFD location
Also consider how you might configure your screens and if that will push the info you want away from center. I wanted to have the artificial horizon part of the PFD directly centered in front of me, but if the screen gets split to display a map or chart the AH gets pushed over to the left. While pondering how to best address this I flew a trip in a G500 equipped Malibu JetProp and found the AH part of the PFD was 5-6” left of center. I had been flying this particular plane for a couple years and had not looked for or noticed this particular detail before. Bottom line is it doesn’t matter much. Things will shift around with different configurations and you will just fly it.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 10-20-2021, 08:37 AM
Snowflake's Avatar
Maybe look at the dimensions from the center of one stick to the center of the other stick?
Rob Prior
Old 10-21-2021, 08:54 AM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
A quick measure on my seat backs shows the centres to be at Y=+/-10.5".
I.e. 21" between H-points.
