Yes, the 80 hp 912 was 1,211cc and 9.1:1 compression ratio. The original flat-four was bumped up to 1,352 cc and 10.8:1 compression ratio to yield 100 hp.
Rotax uses Capacitive Discharge Ignition (CDI) instead of magnetos. The CDI’s are not powered by the battery, but rather by coils on the back of the engine. The engine crankshaft needs to rotate about 250 RPM to generate a spark. So, it’s possible to hand start (especially the lower displacement / lower compression) by back-driving the gearbox. You’d have to spin the prop really hard and fast.
A couple of items….
This minimum speed to attain spark is also why it is advantageous to have battery fully charged for fast cranking. Slow cranking = no spark.
It’s perfectly safe to turn propellor by hand as no spark would be generated at slow speeds.
One add’l item – the Rotax utilizes a Sprag, or overrunning roller clutch, on the starter motor instead of a Bendix drive gear assembly. The reason I mention this is early SN engines do not have automatic spark retard at start. If engine cranks slowly and backfires, it can easily destroy the Sprag clutch. Once again, a fully charged battery is your friend….
