Go Back   VAF Forums > Model Specific > Rocket
Old 06-07-2021, 07:23 PM
andoman andoman is offline
Default HR2 Gear Legs (F1 mod?)
My HR2 is at the ďpaint and panel to goď stage. Fortunately I acquired it that far along.
Iíve read every Rocket thread and searched high and low throughout the RV gear leg stiffener threads.
My questions:
-should I seriously consider the F1 mount and itís tapered socket leg upgrade?
-If not, what gear leg stiffener configuration should I move forward with?
My gear leg stiffener goals are aimed squarely at lessening the aft flexing of the legs during braking given the designís light weight on the tailwheel and very flexible gear legs.
I found this recent -4 thread compelling (see pix links in post #4): https://vansairforce.net/community/s...d.php?t=195959
Thanks in advance and thanks to all the brilliant Rocket and -4 forum contributors over the decades.
Dan
"The plane won't build itself..." RV-7A N7.62MM sold
-RV4 purchased. Extensive refurbishment complete. ďTakes off by itís self, flys hands off, lands by itís self...Ē
-HRII project: paint and panel to go!
Old 06-07-2021, 07:49 PM
rv699jb rv699jb is offline
Default F1 gear
Dan,
Another point to not let lightly slip by, is that the F1 gear mod. moves the tires forward a few inches. This might be more important in preventing nose overs than the stiffness of the legs. I donít think you would be disappointed with the F1 mount and gear legs upgrade.
Jim Baker
RV-6
F-1 Building
Old 06-07-2021, 08:16 PM
Thanks, Jim, for the quick reply.
The improved geometry of the F1 gear is exactly why I’m asking the question.
The majority of the HR2’s seem to be flying fine with the stock gear, but it is less than optimum.
Old 06-07-2021, 08:49 PM
Tom Martin Tom Martin is offline
The standard F1 mount will not fit a HRII fuse as the F1 is wider at the bottom mounts. It might be possible get a special one made. Contact Vince Frazier
Tom Martin
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 06-07-2021, 09:15 PM
Little Al Little Al is offline
Vince @ F1 aircraft now has available an engine mount available for the HR2 that has F1 geometry and accepts the F1 gear legs. Insurance statistic is something like 50% of all HR2s end up on there nose but thats only the ones the insurance knows about. John Harmon will tell you he believes 90% is more accurate. The price of a prop and 540 overhaul I would say YES its worth it.
Old 06-08-2021, 06:00 AM
sailvi767 sailvi767 is offline
The majority if you call that 51% might be doing fine but at least 30% and probably closer to 50% of the Harmon’s have been over on their nose. That is the reason Rockets have such horrible insurance rates. The F1 has been unable to distance itself ftom the Harmon to get lower rates.
The standard rule of thumb for a tail dragger is 5% of the weight should be on the tailwheel. Most F1’s are 50 to 70lbs on the tailwheel. The Harmon’s I have looked at had 20 to 30. A 1300lb aircraft should have 65lbs on the tailwheel.
RV-6 sold
F-1 Rocket
Old 06-08-2021, 11:39 AM
titanhank titanhank is offline
My hr2 had 19 lbs on the tail when i got it. I talked to john and several other rocket guys that recommend 35-40 lbs on the tail. Johnís comment was ď throw a couple cases of oil in the back and go fly, you will love itĒ. I put a 4 gal smoke system in the cargo compartment and added 20lbs of lead dive weight to the aft elevator spar. This gives me 41 lbs on the tail with full smoke oil. It flies beautifully and has no tendency to nose over if you keep the stick back. It flies like a big engine airplane should, you just have to respect it on the ground.
Harmon Rocket #1
IO-540
10-1 pistons
1959 Piper PA22-150 Tri-Pacer
Rv7a sold
Rv6 sold
Rv4 sold
Rv3 sold
Old 06-08-2021, 12:41 PM
Thanks!
I appreciate the comments.
My Rocket has a 15 gal aux fuel tank in lieu of smoke tank.
I really hope to hear more from those with time in HR2’s with standard gear.
Thanks again
Old 06-08-2021, 03:00 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Indeed we do make such a part:
HR2 Rocket Lycoming IO-540 Engine Mount Ė using F1 gear legs and leg geometry
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 06-08-2021, 04:41 PM
I have owned two HRII aircraft and flew a total of 6 or 700 hours on the two of them. I never had the tail come up on the ground but I was really careful. (maybe lucky)
Two real gotcha scenarios; the first is on initial start up; if you look down for a few seconds and the plane starts to roll forward; your head comes up, you jam on the brakes and over it goes.
The second is; heavy application of brakes while taxing. Easily can happen when you are in a line up waiting for clearance, push forward, apply too much brake too fast and over it goes.
When I sold my RV4 the gentleman started the aircraft at a high power setting and it went over as well. Fortunately he had a wooden prop and there was limited engine damage.
The F1 is much more solid on the main gear due to the wheels having been moved forward and also the gear legs are stiffer.
CPL & IFR rated
RV14 Tail dragger
Fairlea Field
