Old 01-03-2021, 12:03 PM
Skepilot Skepilot is offline
Question Map light with focusing lens / adjustable beam width
I'm trying to find a map light which is adjustable, not only in terms of pointing direction, but in terms of focusing / adjusting the beam width. Pretty much every airline cockpit I've ever flown has map lights like this, but I can't find anything like that for GA or experimental airplanes.
I've checked the usual sources: Aircraft Spruce, PilotLights.net, Stein Air, plus some non-aviation sites like superbrightleds.com and other sites which supply lights for boats, RV's, etc., but no luck. Any suggestions?
Mike M
Atlanta, GA
Earn money plane: A320
Spend money plane: Sling TSi
Old 01-03-2021, 01:26 PM
ChrisHodgens ChrisHodgens is offline
Red face Always have a pax
I make my passenger hold a flashlight over my shoulder....
Old 01-03-2021, 10:07 PM
avrojockey's Avatar
avrojockey avrojockey is offline
I think you'll find you may not need all the function of a light designed for variability of airline cockpit that needs to meet the desires of 100s of pilots, but this is similar to the 737 removable flight kit lamp...
https://www.aircraftspruce.com/catal...ockpitspot.php
Tim Holmes
Appleton, WI
RV-9A N904DC
2019-2021 Dues Paid
Old 01-04-2021, 06:04 AM
noelf noelf is offline
Sportie's has a number of flashlights that may work. You will probable need to make your own mount.
Noel
RV-6A N6NF
tip-up
flying
Old 01-04-2021, 07:41 AM
fl-mike's Avatar
fl-mike fl-mike is offline
I have lights similar to these in the canopy frame side-rails. Not too bright, and self-contained. Mine use three LR44 batteries.
No beam adjustment though.
Can even take them off if you need a light under the dash or something.
https://www.ebay.com/c/1656456216
Mike W
Venice, FL
N164WM
Old 01-04-2021, 07:55 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default headlamp
I've read that many people fly with a headlamp at night.
Here's me wearing one after a tough riveting session:
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 01-04-2021, 09:50 AM
rzbill's Avatar
rzbill rzbill is offline
And you can get red head lamps too.
I use one for both night flying and astronomy.
Bill Pendergrass
ME/AE '82
Old 01-04-2021, 10:00 AM
avrojockey's Avatar
The three-pack of Duracells that Costco sells has a red led lamp in addition to spot and flood. I wear this at night. It's nice to have the red lamp for flying and the white light for pre/post flight.
Tim Holmes
Appleton, WI
RV-9A N904DC
2019-2021 Dues Paid
Old 01-04-2021, 05:09 PM
Yeah, I saw the Grimes light, but is too antiquated and ugly for my new, pretty airplane.
I like this one, which is on newer airliners like the A220:
But, it's 28v only, and I can't find anyone who sells it anyway.
Yeah, the beam adjustment seems to be the difficult feature to find.
No way I'm wearing a headlamp AND a headset AND an O2 cannula!
Mike M
Atlanta, GA
Old 01-04-2021, 07:03 PM
AV8ER's Avatar
AV8ER AV8ER is offline
Default FLITELite - Microlight Lip Light
I have panel lights that can be pointed but prefer to use this lip light. Headlamps are nice but the elastic band puts pressure on your head a lot like passive noise cancelling headsets whereas this thing lives on your headset boom. FLITELite makes a bunch of variants to this one to match your flavor of choice.
It weights nothing and as it is always on your headset boom day and night there is no hunting for it when the sun sets mid-flight. It is dimmable and turns on/off with the push of a button while remembering the previous dim setting. I keep a few spare batteries in the plane but it seems to operate for a while on a single set.
- Tim
RV-10 bought not built (Thanks Carl!) www.N7ZK.com
"How's it feel to be the fastest plane in the sky? You were spanking two Cirrus planes, a Mooney, and another plane. I took screen shots" - Quote from the best wife in the world.
