Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
  #21
Old Yesterday, 03:50 AM
Mtherr Mtherr is offline
Thanks for the update Bruno! Great news!
Michel Therrien
RV6A "Second Wind" C-GERZ (born N242UL)
Old Yesterday, 02:28 PM
comatb comatb is offline
Originally Posted by RV-4 View Post
Hello Listers
First, sorry for the long wait for an update..
I was finally able to get airborne today with the weather improving and the strip finally drying out.
The Tailbeacon-X is working just fine in all phase of flight and today I was able to do a flight along the Canadian/US border so that I could get a compliance report from the FAA which I did and as far as I know it is good as there were no Red indications in the report.
For about an hour and a half I did step turns in both directions and all kind of manoeuvers as a way to shield the antenna but the Tailbeacon-X kept on trucking along just fine. So my use of an aluminum plate to mount the beacon doesn't seems to affect it in any way even tough a fiberglass plate will most likely be better.
I could see traffic and weather and the transponder worked as advertised.The GPS ''Nic & NACp'' were showing 10 most of the time which is the max you can get.
So for the ones of you thinking of doing the same I did, I think that the results are good and that you can go ahead with your installations.
Best of luck
Bruno
rv4@videotron.ca
Bruno, we are glad to hear that your efforts have been rewarded. Thank you for the update. Just to clarify, did you mount the tailBeacon X in a horizontal plane and not vertically as it was intended by uAvionics?
Old Yesterday, 02:57 PM
It is mounted with the antennas on a vertical plane… see pictures on the page 2 of this thread.
Michel Therrien
Old Yesterday, 08:46 PM
RV-4 RV-4 is offline
Thumbs up Tailbeacon-X
Hi Bill
The beacon is mounted as UaVionix intended (with the antenna vertically) The only difference I used is that I mounted the mounting plate in the horizontal ( it can go either way )so that the two little screws ( about a 1/4 ‘’ ) holding the beacon tightly in place were at a 6 & 12 o’clock position ...
This allowed for a better access to them once the beacon was mounted in the wingtip..
Hope this helps
Cheers
Bruno
Old Yesterday, 08:48 PM
Hi Bill
Hope this helps
Cheers
Bruno
Thanks Michel and Bruno.
Bill
