Old 03-18-2006, 12:46 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
Thanks Chad. I think you and I last bought it during a sale that was running in the fall. Unfortunately I haven't seen that sale running again and the guy at the store said he's never been able to predict when stuff will be on sale. If anyone hears that Napa has a sale going, by all means post the news--it's definitely worth buying then!
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2022
Old 03-18-2006, 11:48 AM
cjensen's Avatar
cjensen cjensen is offline
absolutely!! i will tell if i hear of it...
Chad Jensen
Astronics AES, Vertical Power
chad.jensen@astronics.com
920-216-3699
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 03-18-2006, 10:14 PM
osxuser's Avatar
osxuser osxuser is offline
Aircraft spruce carries Zinc Chromate for a touch over $6 a can, I think thats what I'll use. It's very recognizable for most A&P's and it's easy to use and dries almost instantly in a warm climate. I plan on priming only non-alclad parts and perhaps the seams, we'll see.
http://www.aircraftspruce.com/catalog/cspages/zinc.php
RV4 wing in Jig @ KPOC
RV7 emp built
Old 03-19-2006, 06:35 AM
Ironflight's Avatar
VAF Moderator / Line Boy
When I decided on my rattle can primer I tested several different types. If I recall correclty, the stuff from ACS was not self etching, and I could scratch it off with a fingernail. I hope I am remembering this incorrectly, but you might want to test before you buy a case!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-19-2006, 08:42 AM
jcoloccia jcoloccia is offline
Paul
I believe you're correct, Paul. I got my chromate from Redden Marine Supply. It's still Tempo, just the self-etching variety. Nice stuff, designed for below waterline use.
Problem is that you CAN scratch it off with a fingernail, even the self etching stuff, until it's dried for about a week. Bummer....that's why I don't use it anymore. I let a test piece sit around for about a week, and the stuff is tough as nails when it's fully hardened but who the heck wants to wait a week to rivet?
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
Old 03-19-2006, 03:46 PM
mgomez's Avatar
mgomez mgomez is offline
Default Buy a LOT of 988
I've been using Sherwin Williams 988 on my mating surfaces. Only for small areas (ribs, spars, etc.) do I prime the whole thing. Mine is a QB, so there's a lot of it that I'm not priming at all, because it's already put together.
My advice is to buy a LOT of rattle cans. I've used about 16 so far, and I've done:
Empennage
Seats
Rudder
Ailerons & Flaps (I'm painting the rear spar, aileron gap seal, flap brace, etc. where water might pool)
Pushrods, inside and out
The cans don't go very far, at least not if you do two coats.
Martin Gomez
Redwood City, CA
"My RV-7 is a composite airplane: it's made of aluminum, blood, sweat, and money"
RV-7 Slider QB
Old 04-04-2006, 06:04 PM
N941WR's Avatar
N941WR N941WR is offline
Ok, I'll bite.
The future N941WR was primed, after alumini prepping and alodining, with SEM Self Etching Primer.
The stuff seems to work well, but then again, my -9 is still in my hermetically sealed basement.
It was recommended to me by another RV builder/flier and he is still happy with the results.
One thing I really like about using the spray cans is that clean up is VERY easy. Just put the can back on the shelf.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-04-2006, 06:19 PM
apatti apatti is offline
I just started using the SEM rattle cans as well. I like it. However, I don't acid etch and alodine any more. A couple of years ago at Sun n Fun, Tom Greene told me that was redundant. I just clean the surface, scuff with a Scotchbrite pad, clean it again, clean it again, and then hit it with the SEM. It dries very quickly and seems very durable. And, as said before, clean up is a breeze! Comes in a variety of colors ,too.
Does anyone know how to safely discard spent alodine??
Tony
RV8A
N97AP
Warner Robins, GA
Phase I complete
Old 04-04-2006, 06:41 PM
Aviator Aviator is offline
Default Dupont in a rattle can
Relative new comer and aimed to catch the market is the offering from Dupont. I get this from auto refinishing store.
The primer is A 4115-S, comes in green and grey. I like it better than the Sherwin williams product ( which is smme as the NAPA) and the SEM.
I have tried to attach a pic.
RV 10, still building.
Chattanooga, TN.
N724AR reserved
EAA # 706863. Chapter 150.
Exempt, but donated Jan 2018
Old 04-07-2006, 12:20 AM
AX-O's Avatar
AX-O AX-O is offline
Originally Posted by cjensen
sorry steve, i forgot about this until i went to pick up another case of six cans today. my last purchase of six was $25.72...boy was i in for a suprise today!!! $49.56!!! i don't know what happened between november and today, but it's up to $7.60/can before tax.
Just picked up 2 boxes of NAPA 7220 self etching primer. Each box was approx $26. Got 2 because I saw the post above and figure maybe they gave me and wrong price.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
