Old 04-07-2021, 03:20 PM
David Carter David Carter is offline
Default Using TurboCAD to import Aeroelectric diagrams?
Anyone on here have any success using TurboCAD to design their electrical system? I'm tying to use it to import one of the Aeroelectric diagrams as a starting point, but I'm finding it extremely difficult to work with the imported diagram. Examples - the symbols aren't grouped into a single item that can be manipulated, the connections between components don't move when you move the component, etc. I'm sure I'm not doing something correctly here.
Thanks for any tips.
David
RV-7A Slider N87BP (bought flying in 2018)
Superior XP-IO-360, Hartzell G2YR/N7605W-2X
AFP Fuel Injection & Dual SDS CPI-2 ignition
KLZU - Lawrenceville, GA
2020 Dues Paid
Old 04-07-2021, 05:48 PM
terrye terrye is offline
Haven't used Turbocad, but Autocad and Draftsight allow you to create a "block". Use "define block" or "make block". This allows you to select the line segments that are used for a symbol and save it either inside or outside the drawing (so you can re-use it in other drawings). Once created, you can move, drag, delete, etc., or insert the block again in a new location.
Not sure if there is a way to retain the connections of the "wires" between schematic symbols or blocks.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 04-07-2021, 10:21 PM
spark68 spark68 is online now
You can also move the entire set of points without making them a block first by selecting the entire set of points by dragging a selection window over them to select the set, then move command. That's useful if you only move them once.
You would have to move the interconnect lines (the "wires) by dragging them separately, or erase and re-draw them.
I'm using nanoCAD and it works the same way.
Mark Curley
RV-6 - building
dues paid 2021
Old 04-08-2021, 04:13 AM
Mich48041 Mich48041 is offline
Try ExpressPCB classic. It is free but they will ask for your email address. It is intuitive and very easy to learn.
It is not necessary to relearn it after a long period of inactivity. I can email you a schematic to use as a starting point.
Joe Gores
RV-12 Flying
Old 04-08-2021, 09:18 AM
reak's Avatar
reak reak is offline
Yes I did exactly this in about 2006 when working on my RV7A electrical. A DOS freeware copy of turboCad was included with Bobís book back then. TurboCad was hard to use and awkward for schematic capture. I made it work but donít recommend it. Newer versions of TurboCad wonít swallow the schematics or part models. I still use the freeware version if I need to change something. When I upgraded the panel I decided to use a spreadsheet instead of a schematic and that was much simpler and produces better documentation, just my opinion though.
Brad Reak
RV7A Flying, N789W
Loveland, CO
Old 04-08-2021, 11:02 AM
Joe - that would be great. I'm sending you a PM with my email address. I'm not sure I'll go this route, but I'd like to give it a try. I have some other projects where a PCB-specific tool would be helpful. Maybe I can learn it once & kill two birds.
Thanks!
David
2020 Dues Paid
Old 04-08-2021, 11:03 AM
Brad - that's an interesting idea. Would you be willing to share a copy of the spreadsheet format you used?
Thanks!
David
2020 Dues Paid
Old 04-08-2021, 11:04 AM
Default Thank you!
Thanks to everyone else I didn't reply directly to, all of your suggestions were helpful.
David
2020 Dues Paid
