Old 04-06-2021, 05:58 AM
craig.roser's Avatar
craig.roser craig.roser is offline
Do you have pictures of the springs?
Craig Roser
2015 Gunter Malich RV8
2005 Cessna C182T G1000
West Central Florida
Old 04-06-2021, 07:24 AM
Jpm757's Avatar
Jpm757 Jpm757 is offline
Craig,
I will snap a pic next time I'm over at the hangar. The installation is simple, you can shop the spring dept. at your local hardware store. All you need are a pair of light duty springs with the right pull and length, attach them to the back of the rudder pedals opposite to where the rudder cables attach. Attach other end to the firewall stiffener angle with a #40 hole. If you need right rudder in cruise, then adjust the right spring slightly tighter than the left. Usually takes a little trial and error until you get the differential tension required to center the ball.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
(KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis, floats.
Building Javron Super Cub.
2020 dues gladly paid.
Old 04-06-2021, 06:33 PM
wirejock's Avatar
wirejock wirejock is offline
Default Rudder trim
Originally Posted by g zero View Post
Simple Solution....
Brilliant trim tab. Filing that one for someday when my bird is flying.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 04-06-2021, 08:23 PM
gasman gasman is offline
A 1/2 ball off can be as simple as the pedal mount blocks causing too much drag on the tubing.
Reach down and pull the pedal towards you, it should be easy to swing with very little drag.
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
Save the Planet…...............It’s the only place that has beer!
Old 04-07-2021, 10:54 AM
wnplt wnplt is offline
I have this and it works great
https://www.aerosportproducts.com/product/rudder-trim/
Old 04-15-2021, 09:13 AM
Taltruda Taltruda is offline
Originally Posted by wnplt View Post
I don't believe this works on the -8..
Tom
Las Vegas
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 04-15-2021, 09:21 AM
Default From half ball right to half ball left to ball centered
I didn't build my plane but I have made my first custom plane part! It started with a simple AutoCAD drawing that I printed true scale and taped to sheet aluminum. Easy enough to cut out the part with shears and file the perimeter smooth. Mounted behind the stern light with the stern light screws. First flight perfect guess from a half ball right to a half ball left since I wanted to extrapolate to center. First trim got me to a half ball left. Final trim got me to almost perfect. Just a smidge off center.
. . . . g zero gets credit for sharing the design!
Craig Roser
Old 04-15-2021, 09:22 AM
Jeff1smith Jeff1smith is offline
Default Rudder trim
I too had the half ball issue. Started with a piece of balsa wood that I cut with a band saw to a wedge. 3 1/2 in long and 1/2” thick. After looking at it, I just couldn’t glue a piece of wood on the tail. Also looking for a more elegant solution.
Found it at Vans. They sell a metal rudder trim tab for the RV12 for $7.
Asked Vas tech support your thoughts and they approved, so that’s what I did. Looks great and I actually had to take a bit of the delivered angle out, because now I had left ball.
2021 dues paid
Old 04-15-2021, 01:13 PM
Mel's Avatar
Mel Mel is offline
Unfortunately this blocks off the view to the left of your light, making night flight not in conformance with FARs.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 04-16-2021, 04:53 AM
Methinks I am legal, viewable within the 70 degrees side to side required for a stern light:
There is actually a shield on the stern light itself that blocks the view from the side.
Craig Roser
