Old 03-21-2021, 11:54 PM
jliltd jliltd is offline
Thanks, Walt. I went and changed my settings to match yours. Seems to help. However, I found one issue with the dedicated backlight dimmer. The Bus input voltage provided by the dimmer starts at 0.05 volts but the Garmin minimum dim value Bus Voltage value can only go as low as 0.30 volts in the settings. So if I crank the dimmer all the way counterclockwise for maximum dimming I get the opposite once the value falls below 0.30. In other words the lower output of the mechanical dimmer pot provides a way lower voltage than the Garmin can natively detect, more specifically as soon the voltage goes below 0.30 volts the GDU makes the assumption voltage has been lost and goes to full backlight for what I can only assume is a failsafe mode. So at night I will have to be careful not to turn the dimmer all the way down or I will get full backlight brightness instead of the desired eye-friendly dimming.
Maybe using a lower-sensitivity dimmer pot is more compatible with the G3X display and is friendlier to a pilot who tries to go to minimum screen brightness.
RV-8
(a few more airplanes too)
Old 03-22-2021, 06:51 AM
Walt's Avatar
Walt Walt is offline
Jim, you are correct that is somewhat of a limitation on the lower end, never really thought much of it as in reality the display is so dark at that point I don't think you would ever turn it down that far when actually using it at night.
Adding a small resistor to the ground side of the dimmer pot could raise the lower value to say .5 or 1v without much problem. I will experiment with that and perhaps make that a normal addition to the dimmer circuit.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1900+ hrs, New Titan IO-370, Bendix Mags
Old 03-22-2021, 09:13 AM
PilotjohnS PilotjohnS is offline
This topic comes at a good time. I am just about to wire in my dimmers. I will add 500 ohm, 1/4 watt resistors to the ground end of each 10K pot so that the lowest voltage would be about 0.6V
Edit: no need to add resistor. See post below from Garmin tech support
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2021, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 35% canopy done for now
Electrical 85% in work
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
www.pilotjohnsrv9.blogspot.com
Old 03-22-2021, 10:18 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Default Lighting Bus Settings
Jim,
For some reason, Walt's pictures are not showing up for me, what value do you have assigned to Lighting Bus Off Threshold?
Lighting Bus Off Threshold–Sets the lighting bus off threshold input level. At the threshold level, the backlighting is turned on per the Lighting Bus Min setting. Below the threshold level, the backlighting defaults to using the photocell. If the value is set to 0 V, the value will be ignored and the display brightness will remain at the Lighting Bus Min level for any input level between 0 V and the Min Brightness level.
Justin
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 03-23-2021, 08:41 AM
lr172 lr172 is offline
Originally Posted by g3xpert View Post
If the value is set to 0 V, the value will be ignored and the display brightness will remain at the Lighting Bus Min level for any input level between 0 V and the Min Brightness level.[/b]
Justin
I am sure this is obvious to most, however, the reason this default exists is that if you lose your dimmer power supply for any reason, you will likely be unable to see your efis during the daylight if you follow the above approach.
I once thought my mnin-x had died. Turns out that I had turned the dimmer way down (via the menu; no dimmer pot) during a night flight and during the day, it looked like the unit wasn't working. Didn't remember the button presses, so had to push it into the hanger to be able to see it well enough to reset the dimmer value.
Old 03-23-2021, 09:58 AM
Walt's Avatar
Jim,
Justin
So after looking at this a bit closer, the minimum/off threshold setting of 0.3 works perfect.
If you set it at 0v then the switch back to photocell does not occur when you turn off the dimmer and the display remains dark (to the minimum level set).
When set to 0.3v and you turn off the 'dimmer' the screens revert back to auto-dimming, so I wouldn't change a thing.
