Old 03-19-2021, 05:44 AM
Walt's Avatar
Walt Walt is offline
Originally Posted by Skykingbob View Post
These dimmers were recommended to me by the large avionics shop doing my harness. I bought the two pot model for my flood lights I have in my RV8. you can get one to four circuits. They will prefab the harness for an extra fee if you want them to.
https://www.aircraftspruce.com/catal...sptdimming.php
Originally Posted by mfleming View Post
G3X and GAD 27...these are the dimmers SteinAir sent me for my setup.
You don't need big voltage regulating dimmers for the G3X/GTN equipment, the above are for light bulb style dimming where the unit being dimmed is actually drawing current from the dimmer to control it.
The G3X/GTN stuff is voltage sensing and doesn't actually draw any current from the dimmer circuit, it just tracks the voltage which is why a simple pot works fine.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1900+ hrs, New Titan IO-370, Bendix Mags
Old 03-19-2021, 05:46 AM
flysrv10 flysrv10 is offline
Thank you all for your replies.
Old 03-19-2021, 08:35 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Default G3X Touch Backlight
Originally Posted by TShort View Post
So is it for sure 1K?
I've been chasing an issue with mine since the panel re-do 3 years ago. It is SUPER sensitive, and only works through ~5-10% of the range. I've not troubleshot it much as I don't need to adjust the lighting often.
I just looked, and I bought that same model in 10K.
So, if it is supposed to be 1K, I may have found the problem...
Hey Thomas,
Can you email us a screenshot of your Backlight Configuration Menu? We can take a look at the settings and see if there is any room for improvement.
Justin
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 03-19-2021, 08:44 AM
snoop9erdog snoop9erdog is offline
Default GTN Self dimming?
Can you go in and dim the GTN or G3X within the unit? If so, is there a real need other than convenience to have the dimmer?
Ed Avila
St. Johns, AZ (SJN)
N646A RV9
Worlds longest RV build...but getting there
Old 03-19-2021, 08:56 AM
Walt's Avatar
Yes you can, but nothing beats the ease of use of a separate pot to adjust.
Old 03-19-2021, 09:45 AM
mfleming's Avatar
mfleming mfleming is offline
Well bummer... these dimmers were expensive...
So will these work with the GAD 27?
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring completed
Avionics harness build in progress
Donated for 2021 and so should you
Old 03-19-2021, 10:05 AM
Walt's Avatar
Yes, just overkill.
Old 03-19-2021, 11:02 AM
jliltd jliltd is offline
Every time I have played with my external dimmer pot during daylight my G3X screen intantly goes so dim it is effectively blacked out where I cannot see anything. Not just gradually but instantaneously. Then the dimmer pot does nothing to help bring it back up. I have to pull the breaker on the GDU dispaly and then reset the breaker to re-boot it in flight. As such I don't ever touch the dimmer knob any more as I would rather not loose primary flight instruments in the air.
RV-8
(a few more airplanes too)
Old 03-19-2021, 11:48 AM
Walt's Avatar
Check your settings Jim, here's a couple of pics to help, these are my settings and should work for most foks, mine works perfect, the first 2 pics are with dimmer bus off, the last pic is with the dimmer 'bus' on at about the 50% dim level.
Old 03-20-2021, 09:29 AM
TShort TShort is offline
Originally Posted by g3xpert View Post
Hey Thomas,
Justin
Justin-
Will do - thanks for the message.
This has been on my to-do list for a while, but I just keep putting it off and using the time to fly instead!
I'll get some screenshots when I am at the airport next.
Thomas
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
