Old 03-09-2021, 09:21 PM
AF_Alan's Avatar
AF_Alan AF_Alan is offline
Default Similar setup, same issue, no solution
Been chasing the same problem and have tried all the suggestions above over last 7 years (560 hours). Dynon skyview with a G5, sl-30 radio, ps intercom, and aeroleds. Louder at higher RPMs and goes away completely if I turn off alt, or strobes, or intercom.
Rewired sections, added filter to leds, checked all ground paths...still haven't found the cause. Sorry I don't have a solution but it became hardly noticeable after the first 100 hours
Alan
RV-9A N984AW
Old 03-10-2021, 08:33 AM
smithflys23 smithflys23 is offline
How is your battery grounded?
Do you have the multi voltage Aeroleds? Allegedly they are “noisier” that the single voltage. Aeroled offers an upgrade program for these lights.
Old 03-14-2021, 02:53 PM
AF_Alan's Avatar
Default Grounded per plans
I bought the Van's FWF kit and followed their plans. Battery to firewall with #2 (I think) cable, braided cable and #2 firewall to engine block, field of tabs for all neutrals on subpanel.
Build was completed in 2013 and I believe the aeroleds are single voltage but not certain.
Good luck
Alan
RV-9A N984AW
Old 03-14-2021, 03:16 PM
tracy tracy is offline
Default Ground Loop
I opened this thread hopping to learn a little about tailwheel landings.
Tracy Willingham
RV-8
Powered Paraglider
Pitts S2B- sold
Chattanooga, Tn
Dues Paid
Old 03-14-2021, 05:00 PM
Good luck
Thanks, Alan.
Old 03-14-2021, 05:01 PM
Definitely not that kind of ground loop.
Old 03-18-2021, 12:02 PM
Dean_aeroleds's Avatar
Dean_aeroleds Dean_aeroleds is offline
Good luck
If they are from 2013 they are multi-voltage. The single voltage units have linear current regulations so they cannot generate any high frequency noise...
