Old 09-07-2021, 10:40 PM
backcountry backcountry is offline
Default Aux fuel - need more fuel
I was wondering if anyone has added aux tanks in the wings that would feed into the standard baggage compartment tank.
Iím 160 lbs and fly solo a lot and sometimes with little people and could put it a good deal of weight.
Old 09-07-2021, 11:05 PM
rgmwa rgmwa is offline
Have a look in the Modifications thread. Several options there for aux tanks. I enlarged my fuel tank (RV-12 Classic) to take 25 gal.
rgmwa
RV-12LR 912ULS
120346
Old 09-07-2021, 11:52 PM
NinerBikes NinerBikes is offline
I’m 160 lbs and fly solo a lot and sometimes with little people and could put it a good deal of weight.
Consider a Sling 2, instead. 39.6 gallons of fuel onboard, in the wings.
The RV-12 has removable wings... fuel tanks would defeat that, plus the spars were never engineered to handle the additional weight of added fuel. Another consideration would be how this affects the CG of the airplane.
VAF dues paid 2022
RV-12, KWHP based
"Time to Spare, go by Air."
Old 09-08-2021, 08:12 AM
you 'could' put quick disconnects on the hoses tot he wing tanks, if you intended on removing the wings. We do something similar for the Panthers.
You 'might' check with Vans engineering on the wing structure to make sure.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 09-17-2021, 04:44 PM
BOORSMA BOORSMA is offline
Default extra fule tank
check out "Modifications you made" posts: Page 24, #234, 7/18/14, Jetguy.
We used his idea and it works great!
D. Boorsma
RV-12, Bakersfield, CA
Old 10-14-2021, 11:25 AM
I wasnít able to get to
I would be interested in seeing it but not sure I know how to search correctly
Old 10-14-2021, 12:05 PM
Mich48041 Mich48041 is offline
BackCountry, here is LINK for you.
Joe Gores
RV-12 Flying
Old 10-14-2021, 02:18 PM
12vaitor 12vaitor is offline
There are/were RV-12s modified with wing tanks a few years ago, basically capped pipes inserted in the wing rib lightening holes and quick disconnect fittings to retain the removable feature. If I recall correctly, there was a small header tank in the baggage area that the wing tanks fed. Van's provided some commentary on the idea.
https://vansairforce.net/community/s...d.php?t=114701
Adding a couple of small Aux tanks with QDs to the inboard sections of the wing may be a more feasible idea than a wing root to tip length replacement tanks.
John Salak
RV12 N896HS
