david.perl
Ive recently noticed the skyview wind speeds are over reading by anything upto 20 knts and are different on each display. If I swap screens, the error does not swap over, it stays on that side.
Ive got dual ADHARs and both read the same inflight
Ive done an inflight compass calibration and get over 100 and that's made it slightly better.
I plan on doing another ground compass swing, however that won't explain the mismatched screen readings.
any ideas out there?
Ive also noticed the skyview forum that Dynon run has server issues and is not running.
