  #21
Old 10-15-2014, 03:20 PM
Paul K Paul K is offline
Possibly, I set the rivets in wet epoxy and they get a good looking over at every oil change. I check the filter just because it is so easy to remove and that let's me see the rivets. I also check any contact points and so far, nothing.
For the future, fiberglass is also available in sock form and you really don't even need to use a sock. I was not going to paint it originally, liking the looks of carbon, but in retrospect would not use carbon again. It's hard to work with.
Paul K
West Michigan
2021 donation made, exempt but worth every dime!
Old 10-15-2014, 06:11 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Originally Posted by Paul K View Post
Scroll,
I created a new picasa page of all the photos I took building the custom snorkel. Made lots of mistakes and would do it differently if I did it over again but here they are:
https://picasaweb.google.com/1033987...eat=directlink
Paul,
I really do appreciate the album. As usual, photos help it all make sense. You would have justified leaving it unpainted.
Scroll
Exemption waived.
Proud and grateful 2022 -=VAF=- Contributor
PS: I am not an influencer. I have no influence. Just ask my kids.
Old 10-15-2014, 08:17 PM
jarhead jarhead is offline
Originally Posted by scrollF4 View Post
You might be surprised at the ductwork in certified helicopters (not just light singles, either) that looks pretty much like your pics above... at 0.0 TSN... from the OEM.
Ken
Helicopter mechanic (A&P)
USAFR KC-10 Boom Operator, on final approach to retirement
My RV-9/8/7 dream may be on life support, but it ain't dead yet!
Old 10-15-2014, 08:41 PM
Bugsy's Avatar
Bugsy Bugsy is offline
Scroll
Is this some Holloween tale, just drill a hole in the front of the cowl like everyone else and skip all this nonsense.
Paul 'Bugsy' Gardetto, Col, USAF (ret)
Milwaukee, Wisconsin (Timmerman Field)
N377KG - Flying (250 hrs)
RV-7A, Aerosport O-360, WW200RV
Advanced Flight 5400
Avidyne IFD440
Paint by planeschemer.com
Old 10-16-2014, 05:11 AM
Originally Posted by Bugsy View Post
Scroll
That's what I did with the 7 and FM200. The engine liked ram air, I could feel difference after take off when it was opened. But then I had a rinky-dink internal filter that could have been improved.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 10-16-2014, 07:33 AM
scrollF4's Avatar
Scroll
Ok, educate me please: Is there a horizontal snorkel option for the horizontal induction IO-360? I agree that it would have been easier to build...
...but my other hangup involves that guppy-mouth intake hole under the prop spinner. I just don't like the look, but I really do love the clean cowling look without the center intake. That's one of several reasons why I chose the IO-360.
Scroll
Exemption waived.
Old 10-16-2014, 08:11 AM
SHIPCHIEF SHIPCHIEF is offline
Your Frankensnorkle made up my mind, I did what Bugsy said.
I just drilled a big hole under the spinner yesterday.
I have a parallel valve IO-360 with Superior cold air sump and Airflow FM-150 injector.
I'm using a nifty tubular aluminum housing with a K&N cone filter inside. That's attached to the injector by a 3" X 4" adapter hose. I'm planning to mold a fiberglass fairing around it...
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 10-16-2014, 06:40 PM
Smilin' Jack Smilin' Jack is offline
Guess I was lucky, with my snorkel missed all the vital components. A lot of
moving and repositioning to make it fit. But with the Precision Throttle body it cleared everything.
Smilin Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
Old 10-16-2014, 07:13 PM
grubbat's Avatar
grubbat grubbat is offline
Default Why not straight in?
Why don't you make a large NACA opening like the Mooney and go straight in to the servo?
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 Built and Flying
1965 Maule M4 Bushwacker projectů till RV-15 shows up
Old 10-17-2014, 12:12 AM
Grubbat,
To answer your question about an NACA duct, on my RV-8: I Trial fit a 7" long piece of 3" hose from the injector body inlet. The end of the inlet hose is mostly outside the slope of the cowl.
If you used an NACA duct, there would be very little to no room for an air filter.
I'm trying pieces from a Spectre universal remote air filter, here is a link:
http://www.summitracing.com/parts/spe-9833/overview/
It has a cone shaped K&N filter inside. I'm ditching the short end and using a 4"x3" reducer hose to connect the wide end to a Flyboy Accessories fuel injector inlet adapter.
http://www.flyboyaccessories.com/Hom...sories-s/3.htm
The smaller inlet end sticks out into the airstream, a few inches behind the propeller.
Scott Emery
2019
