Old 07-09-2019, 11:24 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
As long as we're at it... Here’s a suggestion to keep the latch handle oriented in the open position when the canopy is raised/lowered. Drill a small hole and press in a nickel-plated Neodymium magnet (3/16”∅ x 3/16”) it will hold the steel handle against the stop plate. When lowering the canopy while standing outside of the airplane the handle will often rotate and strike the roll bar preventing the full canopy closure. You then have to climb up on the wing and turn the handle by hand. The magnet fixes this problem…
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 726
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 07-09-2019, 12:38 PM
Tony_T's Avatar
Tony_T Tony_T is offline
The magnet would work but I am a little hesitant to place a magnetic source that close to the magnetometer, in case of the D-180, or the ADAHRS, in case of SV, located a few feet away in the tail cone. It might not be a problem, but the KAI instructions to simply squeeze the tube the handle turns in works well and why deviate from the plans in this regard?
I use a vise grip to do the squeeze, that way you can just barely turn the adjusting screw and do a trial squeeze without over doing it. It is easy to over squeeze and then have a problem getting the handle back in.
Tony
E-LSA RV-12 ULS
SkyView Touch
Old 07-09-2019, 01:21 PM
thorskip thorskip is offline
All I can say is that you all have been very generous with your advice and the pictures tell a lot. It’s true, mine doesn’t have the catch feature. And from what Tony says, even with the adjustments done on the old, it may not be enough, I’ll see. Evidently the new system really is the ultimate answer and I may end up doing that after trying the simple things first. Right now, I’m out of town, but will get on this at the end of the week. Thanks again.
Old 07-10-2019, 11:17 AM
E. D. Eliot E. D. Eliot is offline
Default Thank you all
Not flying yet but I appreciate the contributions that Tony and others have made to my 12 build. The pictures and descriptions are spot on. I reviewed Van's instructions to make this upgrade and decided that I would do it 'some other time'. These pictures have made it more understandable. Thanks again, Tony, and others - I appreciate.
Building finally
Old 07-12-2019, 07:32 PM
I just wanted to post a quick followup regarding my extreme difficulty locking and especially unlocking my canopy on a newly purchased 2013 RV12 with about 60 hrs total time. All the excellent suggestions gave me a direction to go. The very first suggestion and the easiest to try was to remove the shims one at a time. As it turned out, there was only one, so I removed it and, bingo, it was like night and day. That was the answer. It was so easy, why had it not been done by the builder. Before, it took two hands to close with much effort, and opening was even harder to the point I thought maybe I was locked in as the sun was quickly cooking me. Now I just reach up and it easily snaps in and out with one hand. Amazing �� So thanks all, problem solved.
Norm
Old 12-19-2019, 05:42 AM
Major-Tom's Avatar
Major-Tom Major-Tom is offline
Default what switches to buy
I need to buy the mirco switches for the canopy handle and the wing bolts for my 12is locally. Almost every switch will do the job, but it would be nice to have the right bolt pattern. Can someone send a photo of his switches? Thanks
D-MDYZ ICP Savannah-S built, flying, sold www.savannah-blog.de
D-ERVM RV-12iS #121128 99% done, waiting for first flight admission www.tomsworld.de
Old 12-19-2019, 06:31 AM
John-G John-G is offline
Major Tom -
Below are a couple of links to my blog that show the micro switch. As you will read I broke one by stepping on it accidentally and if memory serves me I just ordered the replacement from Mouser an electronics supplier here in the states. The micro switch is a very common design so should be easy for you to find one locally. If you click on the photos on the blog you can enlarge the pictures.
http://www.dogaviation.com/2015/05/c...p-forward.html
http://www.dogaviation.com/2015/05/c...tch-act-2.html
Hope that helps you,
John
RV-12 Wings, Empennage, Fuselage, Finishing, Avionics and Powerplant kits all completed
Now Flying!!
Donation paid until September 2021
Old 12-19-2019, 11:15 AM
Mich48041 Mich48041 is offline
This pdf has a drawing showing dimensions:
https://www.mouser.com/datasheet/2/8...es-1275431.pdf
Van's Plans page 34-11 Cherry Switch E22-50K for Canopy Latch
The switch lever hangs down in the way where it could get bent. You might want to mount it differently.
Joe Gores
RV-12 Flying
Old 12-22-2019, 04:11 AM
Major-Tom's Avatar
Thanks to both of you. This was just the info I needed. I will see if the switches will work in a 12iS too.
