w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 11-09-2022, 10:18 AM
frankd's Avatar
frankd frankd is offline
Default RV-3A Instrument Panel dimensions
Hi RV-3 crew,
I am doing some upgrades to a recently acquired RV-3A. A few questions:
1 Is the instrument panel the same dimension as the RV-4? If not does anyone have a dxf or similar dimensional file?
2 How difficult is the CN-2 MOD to do with the wings removed?
3 Does someone have a W&B Spreadsheet template?
Many Thanks,
Frank
Frank Dombroski
FL KSGJ & NJ KMJX/KBLM
Chronic Offender RV-10 (3), RV-8 (2), RV-7A (2 Upgrades), RV-12
RV-8 2.0 N84FD 2020
Extra EA400 N72JV
RV-3A N21CK Upgrade Project
RV-14A Awaiting Finishing Kit...
Old 11-09-2022, 12:38 PM
Lufthans's Avatar
Lufthans Lufthans is offline
Panel is not the same.
PM me your email address. I have a pdf and dxf here.
(Test on paper first, these are very hand-built aircraft. They are all slightly different)
Hans Teijgeler
Hilversum, The Netherlands
PH-KLT Resurrecting an RV-3B, with Subaru EJ25 STi
PH-BRR Bowers Fly Baby; Imported and upgraded
PH-MGA Jodel DR1050; Built, with Subaru EJ25
PH-SUM RV-4; Imported and upgraded. Sold my share :-(
PH-EIL RV-4; Imported and upgraded for friend. Sadly crashed
PH-ERD Robin DR300; Built with Subaru EZ30 for friend.
Old 11-09-2022, 01:05 PM
hangar7racing@gmail.com hangar7racing@gmail.com is offline
Default Panel
I move mine forward several inches. It gave me a lot more room to get in and out. A photo of it is in another post for Projects.
Old 11-10-2022, 06:49 AM
frankd's Avatar
Default RV-3 Panel
Hans, I sent a pm with my gmail, frankdombroski.
Do you have any detail on the forward movement of the panel and flat dimension on the new panel space?
Frank Dombroski
RV-8 2.0 N84FD 2020
Extra EA400 N72JV
Old 11-10-2022, 08:47 AM
WillG WillG is offline
Default Instrument Panel
[ATTACH]Click image for larger version
Let me know if this does not work.
MG
Old 02-26-2023, 06:15 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Has anyone done a DXF or DWG of a 3B panel?
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 02-26-2023, 07:33 PM
Using that picture of the panel from the plans, the curve isn't smooth. There's a thread somewhere in the RV-3 section, maybe about plans errors, that discusses this.
Dave
Old 02-27-2023, 03:54 AM
Lufthans's Avatar
Here's a couple of links to the files that I have.
Please print the pdf out on paper first to check for fitment. Each RV3 is different, so ymmv...
Good luck!
Hans
Panel dimensions (dxf)
Panel dimensions (PDF)
Instrument cutouts (dxf)f
Hans Teijgeler
Old 02-27-2023, 08:11 PM
FinnFlyer FinnFlyer is offline
Originally Posted by frankd View Post
Hi RV-3 crew,
Many Thanks,
Frank
Quite a bit of work.
You have to drill out enough wing skin rivets to be able to fold back the skin (can use duct tape to keep it folded back) to give you access to drill out rivets and replace with bolts and set 3/16" rivets. I managed to set mine with a 3x rivet gun using a very heavy block of steel as bucking bar. This is not a one weekend project! Are you going to do serious aerobatics (more than 3 to 4 Gs)? If not, I'd consider leaving it alone.
Finn
N214FL RV-4 Mazda 13B Renesis First flight 20 Feb 2021
N46AZ RV-3B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
