Soarandtow
Active Member
Forty plus hours and now very comfortable with my 9. BUT I have a floor vib at higher rpm 2300 and up. It's ok with feet on the floor but if you lift them both up you can hear and feel the vib. Note I have balanced my prop at max static rpm on the ground at 2300 down to .02 IPS which is very good for a fix pitch recip
Prop sensenich aluminum Engine Lycoming 0320
Just wanted to know if anyone else has had the floor vib
