Kevin Nugent
Member
I'm still doing research on the RV 3 & 4 before I pull the trigger on a tail and wing kit. I see from reading posts that some 4's have longer gear legs. Is this something builders started doing or is this something Van's Aircraft did? What is the length difference?I have done a search but sometimes these search functions give you everything except what you want. Thanks. Kevin
