You also will need the long (I think 12") back rivet set, which is available from Cleaveland and others. Also a long no. 30 rivet set for the skin rivets surrounding the spar center section. And long drill bits for any rivets that need resetting. Make sure everything is set up exactly, you may have to turn the fuselage on its side to drill out any mis-set rivets.
Tom
Walnut Creek, CA
RV-14 slow-build - fuselage kit in progress
1949 Cessna 140A - IRAN'd 2017
Dues paid for 2021
