Old 01-18-2021, 04:46 PM
tdavis1198 tdavis1198 is offline
Default Nutplate Issue - Screw does not fit
I am trying to insert the screws that secure the pitch trim servo assembly onto the elevator. I can't get one of the screws to bind with the threads in one of the K1100-06 nut plates. I assume that there is a bit of distortion.
I assume that I will have to tap the nutplate. Is this correct and any suggestions what size and type tap I need to get?
Old 01-18-2021, 05:27 PM
abwaldal@gmail.com abwaldal@gmail.com is offline
Default time to spend money
Time to buy a tap/die set. But if it's not structural I will usually take half the pinch out of the nut so I don't snap the screw off. Been there done that.
Oh as for the call out on the tap. All the numbers are worn off both of my tapes for those.
Art
Old 01-18-2021, 05:42 PM
wirejock's Avatar
wirejock wirejock is online now
Default 6-32
Most common used on the airplane.
4-40, 6-32, 8-32, 10-32, 1/4-28, 3/8-16
Don't buy Harbor Fright. Buy quality taps.
Nothing worse than snapping off a hardened tap in a hole.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Disclaimer
Old 01-18-2021, 10:58 PM
DaveWelch DaveWelch is offline
Default Pre-exercise them
After a similar experience with an installed nutplate that was a pain to replace, I vowed to run a boelubed screw thru every nutplate before riveting them in place. Preemptively Found a few more that would have given me problems.
Dave
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
Old 01-19-2021, 05:53 AM
CJK CJK is offline
Question
New builder here: I've seen a few folks recommend this, and it sounds wise. Is there a particular version of Boelube (paste, gel) that you recommend? Do you just leave it on the threads once you've checked them, or do you wipe it off before installing the fastener for the final assembly?
Chris Klugewicz
fly from KJWN, live near KSRB
RV-14 build imminent
∙ N415EJ reserved
∙ workshop organization in progress
∙ empennage delivered 17 Dec 2020
build log: kitsune.aero
Old 01-19-2021, 08:35 AM
sf3543 sf3543 is offline
You'd be surprised how many times I have found the wrong size nut plate installed or where the threaded part got squeezed by the riveter.
If it is the incorrect size then drill it out and replace with the correct size.
If its the correct size for the screw, then what the others said.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
Old 01-19-2021, 09:41 AM
stigaro stigaro is offline
You may have the same issue a few of us have seen lately. No threads in the nutplate?
https://vansairforce.net/community/s...ighlight=wrong
RV-14A Empennage - 75% complete
2021 Dues paid
Old 01-19-2021, 11:21 AM
wirejock's Avatar
Default Boelube
I prefer the paste blue stuff. Leave it. Unless you're really OCD like me.
Dime. Soak them after in a solvent. Dry. Spray with primer. I use NAPA 7220. I have a section of 1x2 with nails. Heads are cut off. I spray 40 at a time.
Totally unecessary but I do it anyway.
Larry Larson
Estes Park, CO
Disclaimer
