Old 01-10-2021, 01:27 PM
iamtheari iamtheari is offline
Default Alternate air inlet dimpling - pages 47-19 and 47-20
I am a little confused about the steps here. On page 47-19, the call-out says to dimple 4x #30 holes in the alternate air inlet. The following page says to install it to the snorkel with 5x AN426AD4-6 rivets. There is not a step that I see to dimple the remaining hole in the inlet. What did others do here, and how did it turn out for you?
Old 01-11-2021, 10:27 PM
JokerF22 JokerF22 is offline
There are 6 total #30 holes on VA-192A. The top 5 are called out to be dimpled on 47-19, step 10. The nut plate holes are dimpled #40. The center hole of the nut plate isn’t dimpled because it takes an AN515-8R8 screw, which is shown in figure 1 on 47-20. It serves as the pivot point for VA-192B.
Active Duty USAF
RV-14A Complete, FLYING!!!
N410KA, SN140528
https://rv14joker.blogspot.com/
Old 01-12-2021, 09:12 AM
The problem is that the plans seem to get the count wrong. On page 47-19 it says "4X DIMPLE #30 FLUSH THIS SIDE." On page 47-20 it says "5X AN426AD4-6." I'm trying to figure out if the diagram on page 47-19 should read "5X" or if there is a reason not to dimple the fifth hole at that point.
Old 01-12-2021, 12:35 PM
rvbuilder2002's Avatar
It is a typo and should be 5X.
I submitted a notification for it to be changed on a future revision of that drawing page.
Scott McDaniels
Hubbard, Oregon
Old 01-12-2021, 01:47 PM
Thank you. It's so rare that you guys count wrong on the plans that I wanted to err on the side of caution.
