VAF on Twitter:
@VansAirForceNet
  #21
Old 11-29-2022, 07:52 AM
Southern Pete Southern Pete is offline
I like to have a mechanical gauge that works, I find it just takes away one of those nagging doubts. I have had,
No reliable gauges - I didn't like the uncertainty
Automotive gauges and senders - OK initially but gave up
Van's gauges & senders - accurate, especially when it mattered, and reliable most of the time
EFIS gauges with Van's senders - too complicated to set up and trying to be too clever
UMA gauges (below) with Van's senders - only 18 months in seem to be doing OK.
Click image for larger version
Name:	Fuel gauge.jpg
Old 11-29-2022, 01:24 PM
gasman gasman is offline
That gauge would be better if it had no level markings except for full and empty.
VAF #897 Warren Moretti
2022 =VAF= Dues PAID
Old 12-13-2022, 10:30 AM
reak's Avatar
reak reak is offline
My Vans fuel gauges never worked and I tracked the problem to engine start. During the start the battery voltage dropped to below 7 volts and when this happened (often) the fuel gauges quit working and would not restart until a power down. I proved this by removing the fuel gauzes and replicating the problem on the bench with a viable power supply. My conclusion is that itís a design flaw but a silly workaround would have been to power the gauges through a NC push button switch. When the problem happens after startup, push the button and the gauges would reset and work fine. I choose to buy another brand of fuel gauge instead.
Brad Reak
RV7A Flying, N789W
Loveland, CO
