Keep VAF
Going
03-21-2022, 05:27 PM
Question About Pitot / Static Testing for Transponder Certification
I'm helping a friend with his RV-12 Annual Condition Inspection. The Transponder will need re-certification when we are finished. The plane has dual Dynon HDX and Angle of Attack. Pitot, Static and AOA all connect to the ADHRS behind the baggage bulkhead. My question… when performing the pitot / static leakage test, does the AOA need to be blocked off? Would there be a significant leak if the AOA was left open?
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 790
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
03-21-2022, 05:49 PM
A static leak check is done independently of pitot or AOA.
None of the systems are interconnected.
PS: there is no requirement to do the P-S system to just check the transponder.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
03-21-2022, 06:23 PM
Here’s the KAI section showing the Dynon ADAHRS. You can see that the AOA, pitot and static lines are all independent of each other, so no cross venting. And I have never been able to get a good enough seal on my AOA port to perform a leak test of that line.
Bob Y - builder 12iS E-LSA
N569TT first flight 2/9/2020
#121047
03-21-2022, 07:55 PM
Also, be aware that Dynon wants you to use the Pitot/Static test mode when testing the P/S system so you don't mess up the ADAHRS calibration.
A lot of people don't read deep enough into the Installation Manual to find information like this.
https://dynonavionics.com/includes/g...Rev_AJ_v16.pdf
Opinions, information and comments are my own unless stated otherwise.
They do not necessarily represent the direction/opinions of my employer.
Tony Kirk
Van's Aircraft Tech Support (working from home)
RV-7 N777RV, AirVenture 2022 Kitbuilt Bronze Lindy Winner!
RV-6A N57TK, first flight 9/5/05...
Sold in 2011 after 725 hours of pure joy!
04-20-2022, 07:26 PM
Tony,
Thanks for the advice. I need to have mine tested next week. The only avionics shop are is a Garmin dealer and has a disdain for Dynon. I love my HDX! Will make sure that they are aware prior to commencing the test.
04-20-2022, 08:48 PM
Also, the Dynon Transponder checks require manual switching to ALT and GND mode.
Carl N.
RV-8
KAWO
04-20-2022, 10:40 PM
For a VFR check there is no need to simulate altitudes with a pressure/vacuum source. Does he really need an IFR cert?
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
