Keep VAF
Going
01-15-2022, 07:14 AM
Thread title change ???
Hi Joe,
Thanks for all the info you provide here. I follow it as it's very informative and I like to learn stuff when I can.
Even if I have a MT prop, I presume they share most of the same inner mechanics and maintenance.
Maybe someone could change the title of this thread as the posts drifted to prop maintenance and care instead of Aeroshell #5 woes...???
Eric,
2022 =VAF= paid
RV-8 SB #83274
Grove Airfoiled Gear, Wheels & Brakes
VPX-Pro, EFII System 32, EarthX batteries
Aerosport IO-375, MTV-9-B/183
Skyview HDX
C-GEMQ, RV-8, "Dragonfly", flying
C-GNFJ, C72R Cutlass, flying
01-15-2022, 08:15 AM
Originally Posted by bjdecker
Aeroshell 22 might work. Check the MSDS's
Aeroshell is NOT!!!!!! compatible with 6 0r 5!!!!
DAR Gary
01-15-2022, 02:55 PM
meant Aeroshell 22 is not compatible with 5 or 6; 22 is synthetic, installed in all new hartzell props, 5 and 6 are not, will not lubricate properly when mixed with 22, there are other mill spec compliant greases, but verrrrry expensive!
Regards,
DAR Gary
01-16-2022, 10:11 AM
found a source on eBay
eBay LINK >
https://www.ebay.com/itm/15454203758...wAAOSwRpNg-yIJ
It does appear that 5 and 6 and most all of Aeroshell stuff is not being produced now since a major fire at their plant.
WEB LINK Re plant fire>>
https://www.manufacturing.net/safety...-illinois-town
youtube report on plant fire (A SOBERING VIEW) >
https://www.youtube.com/watch?v=XOrxANn92P0
The source on eBay advertises $45 + shipping for a 1 Gal (6.6 lb) bulk can.
I ordered one yesterday and got a response that it was shipping out to me UPS.
No manufacture date was listed. IMO, some 'new' grease has to be better than no grease when you need it and the price was very good compared to other listings on the web - most are in range of $300 +/- for 6.6 lbs.
Jeff Warren
Simpsonville, SC (@SC47 > 10nm NW Triple Tree)
RV14A (N14ZT), Ser#140195
FF 11/24/21; Phs 1 completed
Contribution made 12/9/21 (USArmy 2/67-2/70)
Reason: plant fire web linkS
01-20-2022, 03:10 PM
01-20-2022, 03:46 PM
Originally Posted by propjoe
Well they basically just stated what was already in the manual. No help/ clarification from them; but I honestly wasn't expecting anything from them other than "only use the original grease unless it is tore down" type of line.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
01-20-2022, 09:27 PM
I could go down a really deep path, but I won't.
Lawyers....
That is why I'm here. I work on airliners and military props mostly at work. I have a Cherokee 180 (Fine airplane). I'm pilot. I'm a 36 year FAA licensed Propeller Repairman, at probably the best FAR 145 prop shops in the world, also an A&P...
The whole experimental world fascinates me and scares me both at the same time. I think you can tell from the posts on this particular thread for my excitement and a little apprehension.
Anyway, I'll contribute as I can. I love airplanes and aviation.
Reason: added
01-21-2022, 07:05 AM
Originally Posted by rocketbob
Or just buy a Whirlwind with an oil filled hub and deal with 500 hour inspections. But given the "recommended" servicing of Hartzells with grease may cause other problems with leaks and the other potential problems identified here you may be better off with another brand of propeller and it may be less work and expense to deal with the 500 hour intervals.
Bob - which Whirlwind model are you referring to? My WW200RV has a 650 hour or 7 year teardown, not 500.
Garden City, TX VAF 2022 dues paid
N16GN flying 1,000 hrs and counting on 91E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Pending Repeat Offender - 10 kit is on order. TDI? Turbine? Stay tuned!
01-21-2022, 07:43 AM
Lawyers....
Yep I'm sure it is all a liability thing.
P.S. I enjoy reading your posts! You should start a thread and just occasionally post some awesome pics/ observations from your shop. You could title the thread "Prop musings by Joe". Haha Seriously, I think a lot of people would be interested in reading it.
P.S.S. Thanks for the link to the grease a while back, I ended up just purchases a can from them.
Jereme Carne
PPL
01-21-2022, 08:52 AM
No reference just had it in my head it was 500 hours. Maybe they bumped it up and it was that to begin with.
I was quoted $2K this week for a blade strip/paint/teflons/reseal for a Hartzell so I suggest anyone shopping for a prop take this into account when making a purchase decision.
Bob Japundza CFII A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
