Old 05-02-2018, 12:09 PM
Iluke Iluke is offline
Default Borrow a 2 1/4 instrument punch?
Would anyone be willing to lend me a Greenlee style hole punch in the right size for a 2 1/4 inch steam gauge? I only need to punch 2 holes for AS and ALT gauges as back ups to the Dynon I?m installing. I?d pay shipping of course.
Ivan
Ivan Luke
Hope Valley, RI
RV-7 SB
Almost ready to move to the airport!
2021 dues paid
Old 05-02-2018, 12:13 PM
pa38112 pa38112 is offline
Sure, Send me your address.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 05-02-2018, 12:31 PM
Ivan Luke
21 Forest Glen Dr
Hope Valley RI 02832
Thanks a bunch! I don?t mind buying tools, for only two holes it just didn?t make sense on this one
Ivan
Ivan Luke
Hope Valley, RI
RV-7 SB
2021 dues paid
Old 05-02-2018, 02:23 PM
noelf noelf is offline
Punch a test hole in some scrap metal before committing to the Greenlee punch. IIRC! The greenlee punch makes a different size hole from the hole you get with a true instrument punch.
Noel
RV-6A N6NF
tip-up
flying
Old 05-02-2018, 04:12 PM
cajunwings cajunwings is offline
Default 2 1/4? instrument holes
After a minor modification I’ve had great results with the metal cutting hole saws available at Lowe’s or Home Depot. Cut a test hole in scrap material similar to the panel and test fit the instrument. The hole will likely be slightly oversize. If so chuck the hole saw in a cordless drill, turn it slowly against a belt sander to remove some of the width from the outer teeth and test cut another hole. With a little grinding you can adjust the hole saw to a perfect fit.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 05-03-2018, 05:21 AM
Thanks. Good advice.
Ivan Luke
Hope Valley, RI
RV-7 SB
2021 dues paid
Old 05-03-2018, 08:36 PM
fabricflyer fabricflyer is offline
Ivan, I've got a true instrument punch if you want to use it. It cuts 2 1/4" &
3 1/8" holes. PM me with info if you want to use it.
Allen
Very slow build 7A
