Old 08-04-2020, 12:44 PM
YellowJacket RV9 YellowJacket RV9 is offline
Originally Posted by croner15 View Post
Like others, I also fear they'll just double down on the upper end of the market.
With Epic leaving the kit market, maybe there's room for a new experimental turboprop? Could never afford one, but I'd love to dream about it.
Chris
Chris Johnson
Old 08-04-2020, 01:15 PM
croner15's Avatar
croner15 croner15 is offline
Originally Posted by hecilopter View Post
I want electric! Something 2 seater, 150kts, 3 hour endurance, 30 min recharge time.
I bet Vans will let others try and fail in this space for a few years. Some incredible things could happen if Mr. Musk's batteries eventually flew in a Vans airframe. Give it a decade or so.
Old 08-04-2020, 01:32 PM
Default electric
I saw an article about a 150KW electric motor made by Yamaha...that's around 200hp...just sayin'...
Bob
Aerospace Engineer '88
RV-10
Phase I as of 12-02-2020
Dues+ Paid 2020,...Thanks DR+
Old 08-04-2020, 02:53 PM
PilotjohnS PilotjohnS is offline
Default Trouble with Electrics
The trouble with electrics is the takeoff weight is the same as the landing weight. Let that sink in a little bit and you will discover what it really means.
John S
Dues paid 2021, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Electrical 65% in work
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
Old 08-04-2020, 03:13 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
True, but at least you do not have the C/G going out the aft end of the envelope
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 08-04-2020, 03:54 PM
AlpineYoda AlpineYoda is offline
After seeing Paul Dye’s beautiful jet, it seems a 2 place jet will be really impractical. The range will seem to be the limiting characteristic. I cant see a 2 place net have greater than 250 mile range.
250 mile range for a 2 place jet? Seems low to me. This one has two seats and a 3,450 mile range.
RV-10 build blog -- https://eaabuilderslog.org/?blproject&proj=7ZSwfzr2g
Started 12/19/2019
Engine hung 1/9/2021
Panel in 2Q 2021
Flying summer 2021?
Going for the build speed record. Thanks lockdowns!
N1814T reserved with FAA
Donated Jan 11 for 2021, EAA and AOPA member
Old 08-04-2020, 04:02 PM
Foghorn's Avatar
Foghorn Foghorn is offline
When chasing the tanker!
Jeff Parker
RV8 Fastback - Building (N767TS)
C195 - Flying (N4469C)
2020 dues paid
Old 08-06-2020, 04:02 PM
joe gremlin's Avatar
joe gremlin joe gremlin is offline
Originally Posted by vlittle View Post
Better hurry. Rans is putting an IO340 on their S19.
They are? With all the effort they're putting into the S21 it seems like they've all but forgotten about the S19.
Old 08-06-2020, 04:07 PM
jjbardell jjbardell is offline
They'd have to up the VNE too to make that a viable solution. The S19 is a great platform, but anything that big on it would be economy cruise at VNE. I'd consider an S19 with an O-320-IO-340. I looked online and couldn't find anything on this. Any links available?
Cheers, Josh
Building - Zenith 750 [11323] CruzerDuty27.5
N67LJ RV9-A [90504] - SOLD
N83LJ Sonex [0864] - SOLD
https://rvpilotlife.wordpress.com/blog/home/
Old 08-07-2020, 08:59 AM
Fuel capacity will be an issue as well. Strapping a 150-180 hp motor on a platform that only holds 24 gallons doesn't seem like the best idea. And increasing fuel capacity would take some pretty significant redesign of the wing and/or fuel system.
