I have a strange issue on my 12is (Single screen Dynon with AP) -
I had a trim-up runaway happen mid-flight, luckily during straight and level, which I was able to reverse using pitch down and then pulling the fuse when it got to neutral, as it kept on wanting to go up! Luckily AP wasn't engaged at the time so I noticed it straightaway.
Upon landing I put the fuse back and all was good during ground tests. I assumed there must be an intermittent short to ground somewhere in a pitch up wire, but upon powering up today to test it my pitch up does not work now from either the pilot or co-pilot stick buttons.
However if I go into the setup menu on the Dynon I can pitch up fine when testing it using the soft keys - so to my mind the circuit back to the trim motor from the power module must be ok?
As I'm having this no trim-up issue on both pilot and co-pilot sticks, I'm looking for any ideas on where to start troubleshooting.
From the schematics, it looks like the wiring is independent from the pilot and co-pilot sticks and goes back to separate pins on the AP module and so given that both up buttons are not working, does this point to an issue with the AP module? Any ideas appreciated to help troubleshoot!!
Paul
12-iS #121263
Paul
12-iS #121263
