  #11
Old 07-02-2021, 02:39 PM
Karl Kistler Karl Kistler is offline
Originally Posted by NinerBikes View Post
Is that on display on both Dynon and Garmin glass EFIS's?
I have a Dynon HDX, Garmin??
Old 07-02-2021, 02:56 PM
rvbuilder2002's Avatar
Use of the % throttle position value is a standard operating parameter for the 912iS engine, so both the Garmin and Dynon avionics systems have it incorporated into the displayed info.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 07-02-2021, 03:40 PM
fehdxl fehdxl is offline
Some addition good nuggets of information in the Rotax operating manual.
Fly safe!
Click image for larger version
ID:	13271  Click image for larger version
ID:	13272  Click image for larger version
ID:	13273  Click image for larger version
ID:	13274  Click image for larger version
Old 08-24-2021, 07:11 PM
edmondthx1138 edmondthx1138 is offline
My RV-12iS has Dynon HDX and I am not able to determine how to if the generators switch over at 2,500 during engine start. I've seen it on the G3X.
Anyone figure this out?
Old 08-24-2021, 07:29 PM
Bob Y Bob Y is offline
If I understand your question correctly, when the ammeter goes from negative (discharging the battery) to positive, you’re on the generator. You should notice your HDX getting a bit brighter too.
Bob Y - builder 12iS E-LSA
N569TT first flight 2/9/2020
#121047
Old 08-25-2021, 05:23 PM
Amadeus Amadeus is offline
We have found that in warmer ambient temps, 35-40 percent works well to get a nice smooth start that doesn't jump to an excessively high RPM.
After reading this thread I decided today to attempt a start at 40% throttle. Before today I always turned the key with the throttle at 50% immediately reducing RPM to 2300 - 2500 which leaves the GEN A/GEN B still needing performed. When starting today I still had to reduce RPM immediately but not by nearly as much.
These hot summer days and for hot starts I will turn the key with throttle at 35%. I always learn something reading vansairforce forums!
Purchased N112DR E-LSA flying with 28.2 hours - Thank you David (CraftingN112DR) for putting your skills, knowledge and attention to detail in this RV-12iS!
Dropped at paint shop this morning (July 15, 2021)
Picked up from paint shop (August 14, 2021)
Donated
Old 09-01-2021, 05:16 PM
JwWright57 JwWright57 is offline
Thanks Bob. I had that question also. Maybe the POH should just say “if the amps are positive it’s switched over”
Jeff Wright, Charlotte NC
Rv-12is with 912is and Dynon system.
Certified Aug 2021
Dues paid 2021
Old 09-01-2021, 08:03 PM
NinerBikes NinerBikes is offline
Let your oil pressure get up around 55-60 psi or more at 2000 to 2200 rpm first, for 5-10 seconds, then proceed to 2500+ RPMS... It's a 2 step procedure.
The A and B lane switches lighted, once over 2500 rpm for 5 seconds, CHANGES from Lane B lit to Lane A lit, on your switch panel, not on the glass EFIS. That tells you you're charging at a positive rate and on the alternator.
Donated
RV-12, KWHP based
"Time to Spare, go by Air."
Old 09-02-2021, 08:47 AM
jrtens's Avatar
jrtens jrtens is offline
NO! Your lane lights remain unlit. (They are fault lights) The only indication is a significant jump in amps as your battery begins to charge. For example, with the Earth X battery, my amps usually go up to around 16 to 18 amps. So while you are advancing the throttle, you should be looking at the ammeter for this jump.
Jon
2019 12iS SLSA
Salt Lake Int'l
Old 09-02-2021, 09:25 AM
greghughespdx's Avatar
This is correct. The Lane A and Lane B lights are *fault* lights only, and neither should be lit in normal operations, including during the startup sequence and while the generators kick in. The ammeter is the thing you need to keep an eye on.
If one or both lights are ever lit or flashing, refer to the RV-12iS POH for a list of what the combination of lights means.
From RV-12iS POH 7-12:
7.7.2 ROTAX 912 iS GENERATOR TRANSITION
After engine start, the Rotax 912iS generators will supply
power to the engine computers but not the main bus.
After the engine speed exceeds approximately 2,500
RPM for a few seconds the K1/K2 relay shown in Figure
7-7 will switch, Generator B will begin supplying power to
the main bus and Generator A will supply power to the
engine computers. This transition will be noted on the
Gen Amp Meter (Shown on the EFIS screen)
A table explaining possible Lane Fault light indications and related actions to take are in the POH, in Section 3-4.
Please don't operate the aircraft without being familiar with the contents of the POH.
Greg Hughes - Van's Aircraft - VP/COO
Building RV-8A since Sept 2014
Aurora, OR (EAA Chapter 105)
