Old 08-21-2021, 01:54 PM
rkiefer2 rkiefer2 is offline
Default RV-12 Audio Jacks - Need to Be tightened?
It appears that my audio jacks for the headset on my RV-12 are loose causing weird noises and one connector to not seat all the way (bounces back about 1/8in, guessing wires wrapped around it).
What is the easiest way to gain access to these to tighten? Anyone else experienced this?
Roger Kiefer II
N242VA RV-12 SLSA - Flying/Instructing
EAA Chapter 18 Member
EAA HBP/HBC Volunteer
Wisconsin Fox River Flyer Club Member
Waukesha, WI (KUES)
Old 08-21-2021, 02:15 PM
Bob Y Bob Y is offline
Definitely won’t be easy to reach, unless you, or someone you know, has small hands, but you’ll have to remove the seat ramp to gain access.
Bob Y - builder 12iS E-LSA
N569TT first flight 2/9/2020
#121047
Old 08-21-2021, 03:04 PM
Jamesey Jamesey is offline
Default RV12
On the legacy RV12 access is by a panel on the fuselage side. The wings have to be removed. Access is tight.
Old 08-21-2021, 04:25 PM
DHeal DHeal is offline
When you retighten the jacks be sure to observe the proper use of the plastic insulating "shoulder" washers.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,060+ hours (as of Aug 2021)!
VAF donation through June 2022.
Old 08-21-2021, 06:49 PM
N804RV's Avatar
N804RV N804RV is offline
Try This: https://www.aircraftspruce.com/catal...k_11-18305.php
Ken W.
Mount Vernon, WA
2020 VAF Supporter
Old 08-21-2021, 07:01 PM
rvbuilder2002's Avatar
A common cause of loose jacks is failure of the builder to follow the assembly step that has you reduce the height of the shoulder on the center of the bottom insulator using fine sand paper.
The panels that they mount in are not very thick and the insulator as supplied has a shoulder that is taller than the panel thickness.
If this dimension isn't reduced, the jack will still rotate in the panel even if the nut is fully tightened.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 08-21-2021, 08:52 PM
funflying funflying is offline
Following the plans is always a good thing. I too have the Jack Hack from Spruce and found it very handy to secure the headset jacks.
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 08-22-2021, 11:12 AM
skydiverlv skydiverlv is offline
Originally Posted by N804RV View Post
Invaluable. I love this tool.
Larry Vandegrift
ULPower 260is
Old 09-11-2021, 06:02 PM
Terrybrd Terrybrd is offline
Default Headset jack nut tightening
I had the same problem with my RV-12 and found out that if I put a closed needle nose plier into the jack hole and then pulled the handles apart that it would hold the jack from turning.
Just keep the outward pressure on them and slowly tighten the nut.
It worked great for me and they haven't loosened yet.
You could also grind the outside of the needle nose to get more surface contact inside the jack and keep it from slipping.
