Old 09-07-2021, 09:40 PM
backcountry backcountry is offline
Default Aux fuel - need more fuel
I was wondering if anyone has added aux tanks in the wings that would feed into the standard baggage compartment tank.
Iím 160 lbs and fly solo a lot and sometimes with little people and could put it a good deal of weight.
Old 09-07-2021, 10:05 PM
rgmwa rgmwa is offline
Have a look in the Modifications thread. Several options there for aux tanks. I enlarged my fuel tank (RV-12 Classic) to take 25 gal.
rgmwa
RV-12LR 912ULS
120346
Old 09-07-2021, 10:52 PM
NinerBikes NinerBikes is offline
I’m 160 lbs and fly solo a lot and sometimes with little people and could put it a good deal of weight.
Consider a Sling 2, instead. 39.6 gallons of fuel onboard, in the wings.
The RV-12 has removable wings... fuel tanks would defeat that, plus the spars were never engineered to handle the additional weight of added fuel. Another consideration would be how this affects the CG of the airplane.
Donated
RV-12, KWHP based
"Time to Spare, go by Air."
Old 09-08-2021, 07:12 AM
you 'could' put quick disconnects on the hoses tot he wing tanks, if you intended on removing the wings. We do something similar for the Panthers.
You 'might' check with Vans engineering on the wing structure to make sure.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old Today, 03:44 PM
BOORSMA BOORSMA is offline
Default extra fule tank
check out "Modifications you made" posts: Page 24, #234, 7/18/14, Jetguy.
We used his idea and it works great!
D. Boorsma
RV-12, Bakersfield, CA
