This I s a long process but will find the center. Mount the spinner on the plane with the pitot tube removed. Put the airplane on saw horses. Remove one set of spark plugs, top or bottom. Rig up a method to hold a fine tip marking pen so it will be pointed at the approximate spinner center, a tripod is good for this. Rotate the propeller through several revolutions allowing the marker to draw a small circle on the spinner tip.
Note; the aluminum spinner will need some sort of bushing to keep it from wearing on the aluminum pitot tube.
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
